February 5, 2007, 10:00 |
Hi
I came across the followin
rafal zietara
Rep Power: 17 |
Hi
I came across the following message when I ve installed OpenFOAM on gentoo. icoFoam: error while loading shared libraries: /usr/lib/libz.so: invalid ELF header the problem is with the place where the libraries are in gentoo. In short gentoo puts: shared lib in /lib static archive in /usr/lib libtool script in /usr/lib linker script in /usr/lib that points to /lib FIX for it is simple: cd /usr/lib ln -s /lib/libz.so libz.so after this everything runs smoothly |
Header files not found | kalldrexx | OpenFOAM Installation | 5 | September 13, 2022 07:57 |
header file for strings in udf | sangeeta | FLUENT | 4 | July 6, 2007 00:52 |
Header files | shuo | OpenFOAM Running, Solving & CFD | 1 | September 10, 2006 03:38 |
how to add header file | shanu | FLUENT | 1 | February 14, 2006 09:00 |
uhf.h header file | giridhar_tech | FLUENT | 0 | February 7, 2006 07:51 |
