Problem installing on 64bit with ver13
Old   April 28, 2006, 05:49
Default i'm obviously doing something
Jonathan Gerald Pelham
jonititan is on a distinguished road
i'm obviously doing something wrong but i'm to much of a newbie to know how to fix it
it looks like the bashrc but i have no idea how to edit that over ssh
Checking basic setup...
Shell: bash
Host: comp26
OS: Linux version 2.6.9-22.0.1.ELsmp
User: mea02jgp
User_config: /home1/me/mea02jgp/.bashrc
FATAL ERROR: /home1/me/mea02jgp/.OpenFOAM-1.3/bashrc does not appear to be sourced from:
You need the following at the end of your /home1/me/mea02jgp/.bashrc file:
. /home1/me/mea02jgp/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc
or equivalent depending on the location of the OpenFOAM installation.
FATAL ERROR Foam install directory not set.
Set correct path to installation 'WM_PROJECT_INST_DIR' in /home1/me/mea02jgp/.foam2.3/bashrc
Checking main FOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR --------- env variable not set --------- yes
$WM_PROJECT_USER_DIR --------- env variable not set --------- no
$FOAM_JOB_DIR --------- env variable not set --------- yes
Checking the FOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR --------- env variable not set --------- yes
$FOAM_USER_APPBIN --------- env variable not set --------- no
$FOAM_APPBIN --------- env variable not set --------- yes
$WM_DIR --------- env variable not set --------- yes
$FOAMX_PATH --------- env variable not set --------- yes
$CEI_HOME --------- env variable not set --------- no
$JAVA_PATH --------- env variable not set --------- no
$MICO_ARCH_PATH --------- env variable not set --------- yes
$LAM_ARCH_PATH --------- env variable not set --------- yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Checking the FOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN --------- env variable not set --------- yes
$FOAM_USER_LIBBIN --------- env variable not set --------- no
Software versions
Software Version Location
gcc 3.4.3 WARNING: Conflicting installations:
foam settings: /bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
java 1.5.0_05
foam settings: /usr/local/packages/java/jdk1.5.0_05/bin/java
current path : /usr/local/packages/java/jdk1.5.0_05/bin//java
gzip 1.3.3 /bin/gzip tar 1.3.3 /bin/tar icoFoam *** not installed ***
CRITICAL ERROR
Checking file/directory permissions...
File/directory Set Reqd Crit
Checking networking...
Action Result Crit
Pinging_comp26 Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the Foam enviroment.
The system test has evoked 1 fatal error(s).
The foam installation contains 2 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
jonititan is offline   Reply With Quote
Old   April 28, 2006, 07:14
Default look at that part: FATAL ER
Markus Hartinger
hartinger is on a distinguished road
look at that part:
hartinger is offline   Reply With Quote
Old   April 28, 2006, 08:07
Default > but i have no idea how to ed
Markus Hartinger
use vi, not my favourite, but it is installed on any system
Old   April 28, 2006, 12:32
Default cool i've nailed the bashrc pr
cool i've nailed the bashrc problem but it still isn't recognising commands such as blockMesh
i think its because the gcc compiler is out of date
or something like that
Old   April 28, 2006, 13:14
Default If you make sure your director
Mattijs Janssens
mattijs is on a distinguished road
If you make sure your directory structure is exactly like
http://www.opencfd.co.uk/openfoam/linux.html
and then unpack (tar xzf ...) all, the whole setup should work once you do that
mattijs is offline   Reply With Quote
Old   May 12, 2006, 18:42
Default is there any way to change the
is there any way to change the install path?
i tried messing with the bashrc file in .openfoam-1.2
but that dosen't seem to have worked
Problem in installing OpenFoam15x mmjhuang OpenFOAM Installation 3 March 24, 2009 04:25
Problem installing OpenFOAM 141 sachin OpenFOAM Installation 2 February 22, 2008 10:20
Problems installing OpenFoam on a 64bit machine jango OpenFOAM Installation 1 June 4, 2007 14:53
Problem installing on 64bit with ver13 jonititan OpenFOAM Installation 0 April 28, 2006 05:45
problem about installing FOAM linux freshman Main CFD Forum 6 November 4, 2004 10:59
