Installing 12 after removing 11
Old   August 26, 2005, 05:44
Default I removed 1.1 installation by
Maka Mohu
maka is on a distinguished road
I removed 1.1 installation by changing the name of 1.1 installation folder.
I installed 1.2 as in README.
foamInstallationTest gives OK OK but with two strange lines:
User_config: /home/marwan/.bashrc
Foam_config: /home/marwan/.OpenFOAM-1.1/bashrc sourced correctly.
$FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes
This means that it still sees the old 1.1
the main problem:
runFoamX is not available, only runFoamXHB and it hangs?
can you help?
Regards,
Maka
maka is offline   Reply With Quote
Old   August 26, 2005, 05:50
Default ReleaseNotes-1.2: http://foam.
Chris Greenshields
chris is on a distinguished road
ReleaseNotes-1.2: http://foam.sourceforge.net/ReleaseNotes-1.2
"runFoamX has been renamed FoamX"
chris is offline   Reply With Quote
Old   August 26, 2005, 05:57
Default Thanks. It works. Any idea
Maka Mohu
Thanks. It works.
Any idea why I get .OpenFOAM-1.1 instead 1.2 in the following foamInstallationTest:
Old   August 26, 2005, 06:55
Default See OpenFOAM Message Board: Op
Håkan Nilsson
hani is on a distinguished road
See OpenFOAM Message Board: OpenFoam-Bugs: Typo in foamInstallationTest, version 1.2
hani is offline   Reply With Quote
Old   August 26, 2005, 11:18
Default Thanks!
Maka Mohu
Thanks!
Old   August 26, 2005, 17:17
Default Detailed procedur: I instal
Maka Mohu
Detailed procedur:
I installed both 1.1 and 1.2 together and thought that posting the following procedure may be of help to people that wants to keep two versions of OpenFOAM and switch easiely between them,
(1) {platform} folder: you can put here any third party bindary that is needed for any version, since source set the right path;
(2) {user}-{version} and OpenFOAM-{version} folders: are distinguised by their version, so once can include all versions he likes;
(3) change $HOME/.bashrc to point to the required version;
(4) source $HOME/.bashrc;
Regards,
Maka
Removing solution from DEF after interpolation Massimiliano CFX 0 October 20, 2008 18:17
ICEM, Tetra removing Mikhail CFX 1 July 24, 2008 11:07
Removing lines from partitions Josh FLUENT 7 July 27, 2007 10:33
removing of linux and keeping windows Anja Main CFD Forum 4 August 23, 2006 07:01
removing conduction term Philippe Salama FLUENT 1 June 3, 2005 12:12
