Problem about installation
Old   January 18, 2005, 22:44
Default I have successfully installed
Luckyluke (Luckyluke)
I have successfully installed OpenFOAM in my local machine. Now I want to do my work on a remote cluster. How should I install it? The following is what I do:
I log into the remote cluster and copy all the installation files to it. Then I unpack all the files under the introduction given in "README". But finally I test it by running runFoamX, the error came with "nsd: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory". Then I type "which gcc", it show that the gcc is located in "usr/local/bin" not in my HOME directory. If I run "foamInstallationTest", it warn the gcc and java are conflicting with the old versions in the remote machine. What should I do to make a successful installation?
Old   January 19, 2005, 00:25
Default you have to set up your $WM_P
Kuan Tek Seang (Seang)
you have to set up your $WM_PROJECT_DIR/.cshrc file ... variables like WM_COMPILER_DIR, WM_COMPILER_BIN, WM_COMPILER_LIB have to point to the right location ... you can do the same thing for java ...
Tek Seang
Installation problem Andrei Smirnov (Smirnov) OpenFOAM Installation 21 May 7, 2007 11:15
installation problem Dr C.Bhasker Siemens 1 September 13, 2006 07:01
Installation Problem Sundar.M Siemens 0 June 27, 2006 23:42
Installation Problem Meenu FLUENT 2 April 22, 2006 14:29
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
