Problem Installing OF 1.6 Ubuntu 9.10 (64 bit) - How to use GCC 4.4.1
Old   August 24, 2010, 11:53
Default Same wmake error in Arch Linux
  #21
Gijsbert Wierink
gwierink is on a distinguished road
Dear friends,
I am trying to get OpenFOAM-1.6.x to run on my laptop with Arch Linux (32 bit). OpenFOAM compiles, foamInstallationTest is happy, and tutorials run. But when I try to recompile a solver (e.g. icoFoam as myIcoFoam) I get an error:
linuxGccDPOpt/options:6: *** missing separator.  Stop.
wmake error: file 'Make/linuxGccDPOpt/objectFiles' could not be created
I then added the -P flag in OpenFOAM-1.6.x/wmake/rules/linuxGcc/general, cleaned with
wcleanLnIncludeAll
rmdepall
wcleanAll
rm -rf `find $WM_THIRD_PARTY_DIR/* -name linuxGccDPOpt* | grep -v openmpi`
but still have the same error. Would anyone have an idea? Am I missing some libs or something? Thanks in advance!
Regards, Gijs
gwierink is offline   Reply With Quote
Old   August 24, 2010, 16:40
Retired Super Moderator
Bruno Santos
Greetings Gijsbert,
That's odd... what changes did you make to these files:
Make/files
Make/options
Can you post their contents here?
It's possible that you removed or added a line in the "options" file and didn't add a "\" to the end of it. The character "\", when is the last character in a line, indicates that the "current line is to be continued on the next one". So, it's possible that when you added a line, you either forgot to add "\" at the end; or maybe you did add, but left a space right after it, which will render the "\" useless...
Best regards,
Bruno
Old   August 25, 2010, 03:10
Gijsbert Wierink
Hi Bruno,
Thanks for your reply. I also read about this "last character should be an '\'" issue and that should be ok. The problem even occured for copied original solvers. What I did overlook was that, when compilerInstall is set to System, OF looks for gcc in /bin/, not in /usr/bin/. In /bin/ (at least in my machine) there was no gcc, so I made a link
ln -s /usr/bin/gcc /bin/gcc
In retrospect foamInstallationTest did indicate this, I just overlooked it .
So, now solver recompile and some of my own libs compile, but not all. One was complaining about a UList declaration, which should be ok. It compiles on other systems. Perhaps src did not compile correctly because of the gcc issue. At the moment I am recompiling OF with the soft link to gcc in place, let's see if that fixes it.
Regards, Gijs
Old   August 25, 2010, 05:26
Gijsbert Wierink
Right, that (the gcc soft link) fixed it. The compile error of our own class seemed to have been caused by an iterator definition. I changed it and now it works. Strange that it compiled just like that on my Scientific Linux desktop ... Anyways, it works . Thanks for your reply, Bruno!
Regards, Gijs
Old   May 11, 2011, 07:18
lazio
lrunber is on a distinguished road
I would just like to add that Bruno's solution i.e. Adding -P option to first line of $(WM_DIR)/rules/linux64Gcc/general
Also worked for OpenFoam-1.5-dev on Ubuntu 11.04
Thanks
lrunber is offline   Reply With Quote
Old   August 23, 2011, 12:31
Default Problem installing 1.6.x in Fedora 14
  #26
Naveen
vetnav is on a distinguished road
I am trying to install 1.6.x in my fedora 14, the gcc compiler I have is 4.5.1. In the post #7 Bruno mentioned that 1.6.x builds fine for 4.4.? and above. So, I followed exactly what was suggested in posts #7 and #11, leaving the 32 bit part. But it did not compile properly. Please see the attached log files for Allwmake and foamInstallationTest.
Could somebody please respond. Thinking that 1.6.x will install without giving much trouble, I completely removed 1.7.1 which I have been using for some time. I needed 1.6.x to develop some applications related to conjugateHearFoam (which is not available in 1.7.1) and I don't know how to maintain two versions in the same machine, so I had to remove 1.7.1.
I spent all day yesterday to install 1.6.x and failed in all my attempts. Any help will be highly appreciated as I need this very badly for a conference which I am attending in ten days.
Thank you
File Type: gz installtest.tar.gz (989 Bytes, 0 views)
vetnav is offline   Reply With Quote
Old   August 23, 2011, 16:47
Bruno Santos
Greetings Naveen,
I had to track you down from http://www.cfd-online.com/Forums/ope...tml#post321238 to reply to you
As it turns out, I wasn't able to predict the future, as I later came to know: OpenFOAM 1.6.x, 1.7.0 and 1.7.x are not fully prepared to work with gcc-4.5.x - A few days after the first post on that thread, OpenFOAM 1.7.1 and 1.7.x were ready willing and able to build and work with gcc 4.5.0 and above (at least to 4.6.x, AFAIK so far )
If conjugateHeatFoam is in 1.6.x and not 1.7.1, then it was most likely merged into some other solver... let me see if I can find it for you...
Whoooaa, stop it right there!! OpenFOAM 1.6.x is one thing, OpenFOAM 1.6-ext is a whole other!!! And it's 1.6-ext that has conjugateHeatFoam!
You can get 1.6-ext from here: http://openfoam-extend.git.sourcefor...-ext;a=summary - or better yet, follow the instructions from here: http://www.cfd-online.com/Forums/ope...tml#post299707 - post #25
It should build with gcc 4.5.1 without any problems... or at least I hope so.
As for having both versions available on your system, remove/comment any lines related to OpenFOAM that you have in the file "$HOME/.bashrc" and add these instead:
alias of171='. $HOME/OpenFOAM/OpenFOAM-1.7.1/etc/bashrc'
alias of16ext='. $HOME/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc'
Then whenever you start a new terminal window or tab, you can choose which environment you want by running of171 or of16ext. Keep in mind that you cannot change OpenFOAM environments when on the same terminal window or tab; this means that if you want to run solvers from both versions at the same time, you'll need two separate terminal windows/tabs for running each one.
Good luck!
Bruno
Old   August 23, 2011, 17:20
Joern Beilke
JBeilke is on a distinguished road
"heatTransfer/chtMultiRegionFoam" in v2.0.x should also do the job.
JBeilke is offline   Reply With Quote
Old   August 23, 2011, 20:37
Naveen
@ Bruno
Thank you very much for all the explanation. What an idiot I am to not differentiate between 1.6.x and 1.6-ext. But nothing is straight I tried to install OpenFOAM-1.6-ext. I downloaded the directory using the command given here
http://www.extend-project.de/home/33...16-ext/article
Untarred the folder and ran the system check. After sourcing the bashrc I went into Thirdparty folder and executed AllMake. Then in the top level directory $WM_PROJECT_DIR I ran Allwmake. After building or compiling for more than two hours it gave me errors . More than 24 hours of my patience yielded then and I stopped the compilation process. Please look at the log file and please tell me how can I resolve this issue and install 1.6-ext. Now its almost two days I was just trying to install OpenFOAM.
@ Joern
Thank you very much for the info. I was not aware of it. I will definitely try installing 2.0.x.
Old   August 24, 2011, 16:24
Bruno Santos
Hi Naveen,
Sadly I've never built OpenFOAM 1.6-ext. Ever since I saw how they build the ThirdParty folder, I've steered clear from trying to building it
Using RPM with OpenFOAM is simply unnatural
But I have installed it by using the ready to use Debian packages for Ubuntu, as explained here: OpenFOAM-dev-1.5 or OpenFOAM-1.6-ext under Ubuntu Lucid 10.04 LTS
Anyway, I did tell you to read post #25 in this thread: Extend Project Release 1.6-ext - there you should find a very good instruction list on how to build 1.6-ext.
Another (veeery long) thread about this subject is this one: http://www.cfd-online.com/Forums/ope...m-1-6-ext.html - again, since I'm not familiar with it, I don't know any pointers for it
Good luck!
Bruno
Old   September 20, 2011, 20:27
Santiago
gascortado is on a distinguished road
hi Wyldckat, ]
I have the previously mentioned problem:
gascortado@me257b:~/OpenFOAM/gascortado-1.6-ext/applications/solvers/my_pisoFSI$ wmake all
linux64GccDPOpt/options:6: *** missing separator. Stop.
I installed OF-1.6-ext as you suggested using the Synaptic package manager and everything works fine. I also verified that the "general" file that is in the rules folder has the edited line and it does. However, when I want to compile anything i get this error. Any idea of what to do??
Thanks man
gascortado is offline   Reply With Quote
Old   September 21, 2011, 14:43
Bruno Santos
Hi Santiago,
Mmm... Without more information, I'm going to have to assume that it's happening the same I saw the other day:
  1. Check this file as an example: https://github.com/OpenFOAM/OpenFOAM...x64Gcc/general
  2. Notice this line:
    cpp -traditional-cpp $(GFLAGS)
    In bold is what's necessary for things to get going.
If it still has problems, then I'm going to need to know:
  • Which Ubuntu version are you using?
  • gcc version:
    gcc --version
  • cpp version:
    cpp --version
  • Just to be certain, you installed 1.6-ext from the cae-team/ppa package repository?
  • A full output log of the build process, if there is more than what you posted here.
Best regards,
Bruno
Old   September 22, 2011, 18:14
Santiago
Hi Wyldckat for your help again...
I checked the file OpenFOAM-1.6.x/wmake/rules/linuxGcc/general and it looks like this:
CPP = cpp $(GFLAGS) -P
LD = ld -melf_i386
PROJECT_LIBS = -l$(WM_PROJECT) -ldl
include $(GENERAL_RULES)/standard
include $(RULES)/X
include $(RULES)/c
include $(RULES)/c++
so that "traditional" stuff is missing. I'm using OF-1.6-ext downloaded using Synaptic manager. I cannot modify the file since it says that I'm not the owner.
I have:
gascortado@me257b:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 11.04
Release: 11.04
Codename: natty
gcc --version
gcc (Ubuntu/Linaro 4.5.2-8ubuntu4) 4.5.2
cpp --version
cpp (Ubuntu/Linaro 4.5.2-8ubuntu4) 4.5.2
  • Just to be certain, you installed 1.6-ext from the cae-team/ppa package repository? YES
wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created
that is all it says
Any ideas? Thanks again
Also, as a possible related problem, I am able to compile my solver without problems in my other computer (ubuntu 10.10). I tried coping the executable file to this computer and this is what it says:
gascortado@me257b:~/OpenFOAM/gascortado-1.6-ext/run/testCase5$ ./Allrunbash: ./Allrun: Permission denied
./Allrun just calls my solver
I also tried to compile my groovyBC folder and I get the a similar message:
gascortado@me257b:~/groovyBC$ wmake all
linux64GccDPOpt/options:13: *** missing separator. Stop.
Old   September 23, 2011, 14:22
Bruno Santos
Hi Santiago,
Run:
sudo gedit wmake/rules/linuxGcc/general
It should request your own password for activating super user powers then it should open the file in gedit.
More about sudo: http://en.wikipedia.org/wiki/Sudo
gcc --version
cpp --version
Yep, I figured as much... the "-traditional-cpp" argument should fix the problem.
OK, all still points to needing the missing "-traditional-cpp"...
Ubuntu 10.10 has gcc 4.4.4 (or 4.4.5, not really sure), which doesn't need the option "-traditional-cpp".
Mmmm.... my guess is that during the copying process, it lost the file permissions. Did you zip the files or used tar? Probably zip, so the fix would be:
chown +x Allrun
This will give the file permissions to execute once again.
Yep, same problem... missing "-traditional-cpp".
Best regards,
Bruno
Last edited by wyldckat; September 23, 2011 at 14:23. Reason: Ooops.... it's "-traditional-cpp", not just "-traditional"
Old   September 23, 2011, 18:41
Santiago
Originally Posted by wyldckat View Post
Hi Santiago,
Run:
chown +x Allrun
Best regards,
Bruno
Ok, Here is what I get when I execute
gascortado@me257b:~$ sudo gedit wmake/rules/linuxGcc/general
(gedit:25084): Gtk-WARNING **: Attempting to store changes into `/root/.local/share/recently-used.xbel', but failed: Failed to create file '/root/.local/share/recently-used.xbel.7G1W1V': No such file or directory
(gedit:25084): Gtk-WARNING **: Attempting to set the permissions of `/root/.local/share/recently-used.xbel', but failed: No such file or directory
gedit opens a file "general" at /home/gascortado/wmake/rules/linuxGcc but is blank. The actual general file is located at usr/lib/OpenFOAM-1.6-ext/wmake/rules/linuxGcc
Another thing, I tried
gascortado@me257b:~$ chown +x Allrun
and I got:
chown: invalid user: `+x'
Any ideas man? Thanks yet again
Old   September 23, 2011, 20:58
lin
Hua Zen
lin is on a distinguished road
chown --> chmod
lin is offline   Reply With Quote
Old   September 24, 2011, 03:21
Bruno Santos
Hi Santiago and Hua Zen,
Hua Zen is right, it's:
chmod +x Allrun
Yesterday I was tired and almost burned out, so I didn't check properly what I wrote.
And I only wrote the partial path because I thought you knew where I was pointing at... so the correct full path should be:
gksu gedit /usr/lib/OpenFOAM-1.6-ext/wmake/rules/linuxGcc/general
And/or for the 64bit version:
gksu gedit /usr/lib/OpenFOAM-1.6-ext/wmake/rules/linux64Gcc/general
edit: another typo I remembered: it's gksu, not sudo, for running gnome apps as root!!!
Best regards,
Bruno
Old   September 27, 2011, 20:08
Santiago
Hi Wyldckat,
I did what you recommended and my files look like this now:
CPP = cpp -traditional-cpp $(GFLAGS)
LD = ld
PROJECT_LIBS = -l$(WM_PROJECT) -liberty -ldl
include $(RULES)/X
include $(RULES)/c
CPP = cpp -traditional-cpp $(GFLAGS) -P
LD = ld -melf_i386
include $(RULES)/X
include $(RULES)/c
However when I try to run wmake as before I get the same error:
When I close gedit after running
or
I get the following messages that I don't know what they mean, take a look:
((gedit:31604): Gtk-WARNING **: Attempting to store changes into `/root/.local/share/recently-used.xbel', but failed: Failed to create file '/root/.local/share/recently-used.xbel.AFOH2V': No such file or directory
(gedit:31604): Gtk-WARNING **: Attempting to set the permissions of `/root/.local/share/recently-used.xbel', but failed: No such file or directory
(gedit:31604): Gtk-WARNING **: Attempting to store changes into `/root/.local/share/recently-used.xbel', but failed: Failed to create file '/root/.local/share/recently-used.xbel.SREG2V': No such file or directory
Any ideas??? THanks again
Old   September 28, 2011, 08:00
Santiago
Hi Wyldckat,
I figured out the problem. I erased the folder linuxGccDOpt and re-run wmake all and that did the trick. Now I have other problems:
When I hit
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/usr/lib/OpenFOAM-1.6-ext/src/dynamicMesh/dynamicFvMesh/lnInclude -I/usr/lib/OpenFOAM-1.6-ext/src/dynamicMesh/dynamicMesh/lnInclude -I/usr/lib/OpenFOAM-1.6-ext/src/meshTools/lnInclude -I/usr/lib/OpenFOAM-1.6-ext/src/turbulenceModels/incompressible/turbulenceModel -I/usr/lib/OpenFOAM-1.6-ext/src/transportModels -I/usr/lib/OpenFOAM-1.6-ext/src/transportModels/incompressible/singlePhaseTransportModel -I/usr/lib/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -DFACE_DECOMP -I/usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement/fields/tetPointFields -I/usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement/tetFemMatrix -I/usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement/tetPointMesh -I/usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement/tetPolyMesh -I/usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement/tetPolyMeshFaceDecomp -I/usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement/tetFemSolution -I/usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement/tetPolyMeshFaceDecomp/tetPolyBoundaryMesh -I/usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement/tetPolyMeshFaceDecomp/tetPolyPatches/tetPolyPatch -I/usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement/tetPolyMeshCellDecomp -I/usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement/tetPolyMeshCellDecomp/tetPolyBoundaryMesh -I/usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement/tetPolyMeshCellDecomp/tetPolyPatches/tetPolyPatch -I/usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement/fields/tetPolyPatchFields/tetPolyPatchField -I/usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement/fields/elementFields -I/usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement/elementMesh -I/usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement/fields/elementPatchFields/elementPatchField -I/usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement/tetPolyMeshFaceDecomp/tetPolyPatches/faceTetPolyPatch -I/usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement/tetPolyMeshCellDecomp/tetPolyPatches/faceTetPolyPatch -I/usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement/tetPolyPatchInterpolation -I/usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement/tetPolyPatchInterpolation/tetPolyPatchInterpolationFaceDecomp -I/usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement/tetPolyPatchInterpolation/tetPolyPatchInterpolationCellDecomp -I/usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement/fields/tetPolyPatchFields/basic/fixedValue -I/usr/lib/OpenFOAM-1.6-ext/src/dynamicMesh/meshMotion/tetDecompositionMotionSolver/lnInclude -IlnInclude -I. -I/usr/lib/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/usr/lib/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64GccDPOpt/tractionDisplacementFvPatchVectorField.o Make/linux64GccDPOpt/my_pisoFsi.o -L/usr/lib/OpenFOAM-1.6-ext/lib \
-ldynamicFvMesh -ltopoChangerFvMesh -ldynamicMesh -lmeshTools -lincompressibleTransportModels -lincompressibleTurbulenceModel -lincompressibleRASModels -lincompressibleLESModels -lfiniteVolume -llduSolvers -lfaceDecompFiniteElement -lfaceDecompositionMotionSolver -lOpenFOAM -liberty -ldl -lm -o /home/gascortado/OpenFOAM/gascortado-1.6-ext/applications/bin/my_pisoFsi
/usr/bin/ld: cannot find -liberty
collect2: ld returned 1 exit status
make: *** [/home/gascortado/OpenFOAM/gascortado-1.6-ext/applications/bin/my_pisoFsi] Error 1
And I'm also trying to compile an older version of groovyBC that I modified and successfully compile on my other computer (Ubuntu 10.10) but not here. THis is what I get:
gastascortado@me257b:~/groovyBC$ wmake libso
SOURCE=PatchValueExpressionDriver.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -IMake/linux64GccDPOpt -DFOAM_DEV -I/usr/lib/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -IlnInclude -I. -I/usr/lib/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/usr/lib/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/PatchValueExpressionDriver.o
SOURCE=groovyBCPointPatchFields.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -IMake/linux64GccDPOpt -DFOAM_DEV -I/usr/lib/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -IlnInclude -I. -I/usr/lib/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/usr/lib/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/groovyBCPointPatchFields.o
In file included from Make/linux64GccDPOpt/location.hh:44:0,
from PatchValueExpressionParser.tab.hh:65,
from PatchValueExpressionDriver.H:59,
from PatchValueExpressionDriver.C:34:
position.hh: In function âbool pve:perator==(const pve:osition&, const pve:osition&)â:
position.hh:136:69: warning: suggest parentheses around â&&â within â||â
from groovyBCPointPatchField.H:59,
from groovyBCPointPatchFields.H:37,
from groovyBCPointPatchFields.C:34:
PatchValueExpressionDriver.C: In member function âvoid Foam::PatchValueExpressionDriver::writeLines(Foam: :Ostream&) constâ:
PatchValueExpressionDriver.C:384:5: error: âFoam::HashTable<Foam::interpolationTable<double>, Foam::word>::const_iterator::const_iteratorâ names the constructor, not the type
PatchValueExpressionDriver.C:384:5: error: expected â;â before âitâ
PatchValueExpressionDriver.C:384:5: error: statement cannot resolve address of overloaded function
PatchValueExpressionDriver.C:384:5: error: âitâ was not declared in this scope
make: *** [Make/linux64GccDPOpt/PatchValueExpressionDriver.o] Error 1
make: *** Waiting for unfinished jobs....
Any ideas? Thanks a lot
Old   October 1, 2011, 11:50
Bruno Santos
Hi Santiago,
No need to worry, they are just warnings
Good old missing "libiberty.so" problem. Run:
sudo apt-get install binutils-dev
As for Groovy, try running:
wclean all
wmake all
Best regards,
Bruno
Problem installing OF 1.5 on Ubuntu 9.05 smart OpenFOAM Installation 18 August 10, 2009 19:12
Problem in running fluent 6.3 (64 bit) on ubuntu 8.1 (64 bit) Mir5 FLUENT 3 April 29, 2009 10:32
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 04:48
OF Installation Problem - Gcc Error Daniel Pilatti OpenFOAM Installation 11 April 19, 2009 22:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
