November 25, 2009, 15:02 |
#21 |
sayed
Rep Power: 16 |
Fabian ,, i did complete compilation and it takes nearly 5 hours !! useing that command /Allwmake and i saw the giant "make.log" file
Bruno , thanks for this links ,, i wonder if the "OpenFOAM 1.6 User Guide" have a pdf approach so i can download it all , and print it all , it will be more easy to learn than reading from screen in my opinion best regards |
November 26, 2009, 07:35 |
#22 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hello Sayed,
Also, on one of the links, you have the downloadable PDF versions. Best regards, Bruno |
November 26, 2009, 08:30 |
#23 |
sayed
Rep Power: 16 |
thanks Bruno ,, that is exactly what i need
December 1, 2009, 08:47 |
#24 |
sayed
Rep Power: 16 |
sorry guys , it is me again ,, i have a problem about the font of the UserGuide.pdf file ,, it's font not obvious and hard to read ,, does any one have the same file but with a readable font ,, or have any other solutions
thanks.. |
December 1, 2009, 10:02 |
#25 |
Bruno Santos
Rep Power: 128 |
Hello Sayed,
Uhm... I have a faint memory about some other version of the document, but it's only a fragmented memory... you can try searching this forum for it. Anyhow, you can also try using pdfedit, which is available for OpenSUSE directly from here, or see here on which and how to add repositories in OpenSUSE (namelly, the packman repository). With pdfedit you might be able to change the base fonts of the pdf and force it to have a more readable font. Best regards, Bruno |
January 14, 2010, 06:56 |
Temporary Work-Around for Mandriva "source .bashrc" TMOUT issue
#26 |
Wesley T.
Rep Power: 17 |
Sayed,
It looks like you found a solution that works for you (changed distributions), but I am sure there are others out there that use Mandriva. Hopefully this post will be of some use to them. I have tried quite a number of linux distributions, and have yet to find a "perfect" one. They all have their limitations. I would suggest that if a person is looking for a distribution ready to go with OpenFOAM, CAELinux fits the bill nicely. In previous versions of Mandriva, I had managed to find where TMOUT was defined for msec (which seems to be what prevents a user from using the source command on a modified .bashrc file). I have not yet found it on Mandriva 2010, the distribution I am currently using. The work-around I am currently using: create a new file (for the sake of this post, let's call it .bashrc2, put it in the same directory as your .bashrc file) Put the line: . $HOME/OpenFOAM/OpenFOAM-1.6/etc/bashrc into it, save the file. Open a terminal and type: source .bashrc2 That terminal window now has the OpenFOAM commands sourced. Go to the directory with your simulation and you are ready to run. Please note that the source command works for that terminal window and that terminal window only. If you close the terminal window, you will need to run "source .bashrc2" again. If you also happen to be running SalomeMeca, you could put the line for the source command in there also. When I find a more satisfactory solution, I will try to remember to post it. Wesley |
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 7 | January 19, 2010 15:39 |
Critical errors during OpenFoam installation in OpenSuse 11.0 | amscosta | OpenFOAM | 5 | May 1, 2009 14:06 |
Problem installing OpenFOAM 1.5 installation on RHEL 4. | vwsj84 | OpenFOAM Installation | 4 | April 23, 2009 04:48 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
