make: Target `application' not remade because of errors.
Old   August 25, 2010, 14:15
Exclamation make: Target `application' not remade because of errors.
maysmech's Avatar
maysmech is on a distinguished road
Dear Foamers,
i tried to install Of1.7.0 on Ubuntu 10.04.
after typing ./Allwmake and after more than 3 hours this message is appeared:
but by typing foamInstallationTest no error is detected. what is the problem?
make.log file is attached.
Thanks in advance
Maysam
maysmech is offline   Reply With Quote
Old   August 25, 2010, 16:16
Retired Super Moderator
Bruno Santos
Greetings Maysam,
The problem is related to a missing X11 header file, which leads to only foamToTecplot360 not being built.
A list of packages for Ubuntu 10.04 and OpenFOAM 1.7 is available here: http://www.cfd-online.com/Forums/ope...tml#post268828
If you use the command line given at that post, and then run Allwmake again, you should no longer have any problems
Now, I will answer to your other thread shortly...
Best regards,
Bruno
Old   August 25, 2010, 17:32
maysmech's Avatar
foamToTecplot360 problem is solved by your guides.
Thank you very much
Old   November 4, 2010, 06:02
Exclamation
Sale is on a distinguished road
Dear Bruno,
I am new to linux and I am trying to install OpenFOAM1.7.1 on RedHat 5.5.
With the foamInstallationTest no error is detected, but when I execute ./Allwmake , I have this error:
I attached also the make.log file.
Can you help me, please?
Thanks in advance
Sale
Sale is offline   Reply With Quote
Old   November 4, 2010, 18:31
Bruno Santos
Greetings Sale,
Mmm, this is a bit odd... OK, there are three possibilities that I can image about this problem:
  1. Links were unpacked from the OpenFOAM 1.7.1 source package. Try running this:
    cd $WM_PROJECT_DIR
    rm -rf src/OpenFOAM/lnInclude
    And run Allwmake again.
  2. Which gcc version are you using?
    gcc --version
    Is it at least 4.3.1?
  3. If neither of the above are the problem, then one or more files weren't properly unpacked. It happens once in a while, although it shouldn't happen at all.
    If this is the case, try this:
    cd $WM_PROJECT_INST_DIR
    rm -rf OpenFOAM-1.7.1/src/OpenFOAM
    tar -xzf OpenFOAM-1.7.1.gtgz OpenFOAM-1.7.1/src/OpenFOAM
    If I'm not mistaken, these commands will remove the current OpenFOAM library and unpack the original one from the downloaded package. You can run Allwmake once again.
By the way, have you tried CentFOAM? http://www.cfd-online.com/Forums/ope...-released.html
Best regards,
Bruno
Old   November 5, 2010, 09:39
Dear Bruno,
thank you for your reply, but no of your suggestions worked. However I tried CentFOAM and it works!
Now I am trying to instal ParaView, so I downloaded qt-x11-opensource-src-4.3.5.tar.bz2 , I unpacked it with:
tar -xjf qt-x11-opensource-src-4.3.5.tar.bz2
then I run:
./makeQt
but the answer is:
bash: ./makeQt: No such file or directory
What's the problem?
Thanks in advance!
Sale
Old   November 5, 2010, 10:05
Bruno Santos
Hi Sale,
If CentFOAM is working, then you should also be able to install ParaView that comes with it as well!
Best regards,
Bruno
Old   November 5, 2010, 10:29
Kathrin Kissling
kathrin_kissling is on a distinguished road
Hi Sale,
have a look at
http://www.cfd-online.com/Forums/ope...directory.html
Maybe you need the Path to Qt4.3.5 by
PATH=...whereeverItIs/Qt4.3.5/bin:$Paraview3.3
(this was somewhere on the forum as well but I cannot remember where, sorry)
For me it worked perfectly...
Hope this helps
Kathrin
kathrin_kissling is offline   Reply With Quote
Old   November 5, 2010, 11:24
Bruno,
if I follow OpenFoam example:
mkdir -p $FOAM_RUN
cp -r $FOAM_TUTORIALS $FOAM_RUN
cd $FOAM_RUN/tutorials/incompressible/icoFoam/cavity
blockMesh
icoFoam
everything looks ok, but then, with paraFoam, the result is:
/home/openfoam/OpenFOAM/OpenFOAM-1.7.0/bin/paraFoam: line 132: paraview: command not found
I supposed Paraview is not installed. What do I have to do?
kathrin_kissling,
what do you mean with:
PATH=...whereeverItIs/Qt4.3.5/bin:$Paraview3.3 ?
Should I add this path to the bashrc file that is in /etc?
Thank you both for the quick answer.
Sale
Old   November 5, 2010, 11:30
Anyway
qmake --version
gives me
bash: qmake: command not found
Old   November 6, 2010, 05:19
Bruno Santos
Hi Sale,
How exactly did you install CentFOAM? If you used the install script:
Originally Posted by http://sourceforge.net/apps/mediawiki/centfoam/index.php?title=Main_Page
I've made a bash script which makes installation much easier
The usage is
./centFOAMInstall yum|OF17|paraview|Netgen|Engrid|Gmsh|all|help
The options are pretty much self explaining except "all" which installs OpenFOAM, Paraview, Netgen, Engrid and gmsh. The script will prompt the user for installation directory and check whether this is writable.
Then it should have been as easy as running:
./centFOAMInstall paraview
Best regards,
Bruno
Dynamic moving mesh Pei-Ying Hsieh (Hsieh) OpenFOAM Running, Solving & CFD 64 June 7, 2012 10:04
Help in Instalation of OpenFOAM duartealbuquerque OpenFOAM Installation 3 March 11, 2009 23:44
Problems compiling OpenFOAM15 on Debian Etch geoffjay OpenFOAM Installation 1 February 5, 2009 16:29
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
a way to make lots of money quick and easy no lies Dob Main CFD Forum 0 October 10, 2006 16:45
