Instell OF 2.1.0 on suse enterprise with suse rpm
Old   January 20, 2012, 08:00
Default Instell OF 2.1.0 on suse enterprise with suse rpm
Stefan
preibie is on a distinguished road
I want to install the new OpenFoam release 2.1.0 on our server. On this Server is Suse Enterprise server running. On openfoam.org I see that there is an RPM for suse (11.4) online. Now I want to use this for the suse enterprise server.
Has somebody tried this before? Is there any reason why this will not go?
preibie is offline   Reply With Quote
Old   January 21, 2012, 13:45
Retired Super Moderator
Bruno Santos
Greetings Stefan,
If it's an up-to-date server edition, then it might work. It might not work because of the GLIBC library version, namely if the version on your server is older than the one used on openSUSE 11.4.
Usually, each Linux version is tightly hooked up to the GLIBC version because it is the backbone of the whole distribution version. If one changes the GLIBC library version, then every single installed application should be rebuilt.
Best regards,
Bruno
Old   February 9, 2012, 04:09
Stefan
Hallo,
now I want to install OpenFoam and need also to install the pattern devel_C_C++ but under SLSE there is no package with this name. Know somebody the name Suse enterprise use.
Preibie
OpenFoam 1.6-ext - RPM build errors preibie OpenFOAM 12 September 8, 2011 03:12
Problem installing OpenFoam-version 1.7.1 on SuSE 11.3 using the RPM Pack lil_jam OpenFOAM Installation 5 April 28, 2011 14:09
OF141dev undefined reference to METIS symbols on SUSE Enterprise matthias OpenFOAM Installation 5 August 29, 2008 10:55
