[swak4Foam] problem while installing swak4Foam on OF-2.0.1
Like Tree3Likes
  • 2 Post By wyldckat
  • 1 Post By gschaider
Old   April 17, 2012, 05:29
Default problem while installing swak4Foam on OF-2.0.1
Laurent Orgogozo
Orgogozo is on a distinguished road
Dear Foamers,
I try to install swak4Foam on OF-2.0.1, but when I run the Makefile I get the following error :
make: ./downloadSimpleFunctionObjects.sh : commande not found
Indeed, the downloadSimpleFunctionObjects.sh script does not exist in my file src/swak4Foam, but it is not present in the downloads I got from svn. At what stage of the installation would possibly lie my mistake? Thank you in advance for your help.
Orgogozo is offline   Reply With Quote
Old   April 17, 2012, 08:16
Retired Super Moderator
Bruno Santos
Greetings Laurent,
From which repository did you download swak4Foam? http://openfoamwiki.net/index.php/Co...am#Downloading
Did you use the command:
Best regards,
Bruno
Old   April 17, 2012, 09:47
Laurent Orgogozo
Dear Bruno,
Yes I did. I have made it once again to be sure :
1) downloading with the svn above,
2) 'wmake all' from within the /opt/openfoam201/ directory
3) 'make install' from within the /opt/openfoam201/src/swak4Foam directory
and then the downloadSimpleFunctionObjects.sh is still missing in the /opt/openfoam201/src/swak4Foam directory.
Best regards, and Thank you for your quick help.
Laurent
Old   April 17, 2012, 10:07
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Originally Posted by Orgogozo View Post
Dear Bruno,
Laurent
downloadSimpleFunctionObjects.sh is no longer required (and therefor is no longer in the repository) as the simpleFunctionObjects are now included with swak. Which script is calling it?
gschaider is offline   Reply With Quote
Old   April 17, 2012, 10:40
Laurent Orgogozo
The Makefile call this script, at line 23
I run the installation while commenting this line, and then it gave me the following error message (last four lines of a quite long compiling log):
make[1]: *** [Make/linuxGccDPOpt/pythonInterpreterWrapper.o] Erreur 1
make[1]: quittant le répertoire « /opt/openfoam201/src/swak4Foam/Libraries/pythonIntegration »
Requirements for Library not satisfied. I see no sense in going on
make: *** [install] Erreur 42
Old   April 17, 2012, 10:54
Assistant Moderator
Bernhard Gschaider
The recommended way of compiling swak4Foam is "./Allwmake". Installing to global directories can lead to very subtle error conditions (kind of a "DLL-hell". If you don't know what I'm talking about stick with "wmake all"). I will remove this part of the Makefile (and the README). Thanks for drawing my attention to it
Old   April 17, 2012, 12:03
Laurent Orgogozo
Ok ./Allwmake after ./Allwclean works
Thank you for your help, I am now able too enjoy swak4Foam !
Best regards,
Laurent
Old   April 17, 2012, 19:41
Assistant Moderator
Bernhard Gschaider
Best regards,
Laurent
Great.
On a second thought. Could your previous compilation problems have been caused by you not having write permissions to the global folders? Anyway. In addition to Allwclean try removeSwakFilesFromGlobal.sh from the maintainanceScripts once. Just to be sure that no unwanted residuals lie there from your previous experiments (as you're using a "per user" installation now)
Old   April 18, 2012, 05:29
Laurent Orgogozo
Hello Gerhardt,
Ok, done. Effectively I've been obliged to log as root user to instal swak4Foam ; in order to be able to use swak4Foam from within my regular account as a simple user, I've used successfully copySwakFilesToSite.sh.
Best regards,
Laurent
Old   September 25, 2012, 12:25
ali
abigail158 is on a distinguished road
Hi ,
i'm also having trouble with the swak4Foam installation. it seems that it cudnt find any python.h file, while compiling pythonInterpreterWrapper.C.
could someone pls help me to settle this. i attach part of my log installation file.
thnxomuch!
abigail158 is offline   Reply With Quote
Old   September 25, 2012, 12:29
ali
sori, here's the attachment log file!
another error is while compiling the swakCodedFunctionObject.C !!
thanks!
Old   September 25, 2012, 12:53
Assistant Moderator
Bernhard Gschaider
Originally Posted by abigail158 View Post
Hi ,
thnxomuch!
If you don't need the Python functionality then you can happily forget this problem (although I'm wondering why it tries to compile it because in the distributed sources this is not configured and therefor shouldn't be compiled anyway. Exactly to avoid this kind of question)
Anyway: the location of Python.h depends on your distribution and therefor I can't answer this. If locate is configured then "locate Python.h" might help you. Adapt the swakConfiguration file with the results.
BTW: some toy-distributions (SuSE for instance) don't install the headers with Python. They have them in a special package (python-devel or so)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   September 25, 2012, 12:57
Assistant Moderator
Bernhard Gschaider
thanks!
That is because the codedFunctionObject changed its interface from 2.0 to 2.1. I think I answered this recently somewhere else: remove from Libraries/swakFunctionObjects/Make/files the line with swakCodedFunctionObject.C. You probably won't need it anyway
Old   September 25, 2012, 14:09
ali
thanks gscheider!!
that solved the compiling problem for swakFunctionObject!
As for python functionality, i rarely use it, so as u said, i put it aside 1st.
Old   October 29, 2012, 05:43
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
I'm having troubles building swak on OF-2.0.1 as well. It's complaining about missing 'mappedWallFvPatch.H' and related files. Is it possible this was added on by OpenCFD at a later release or is my installation botched? (the file is indeed not to be found in my OF-2.0.1 installation, but is there in OF-2.1)
- Anton
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   October 31, 2012, 18:58
Bruno Santos
Hi Anton,
I think Bernhard didn't want to waste any more time with such an old version of OpenFOAM
Anyway, I've done some trials+errors+fixes+tests with OpenFOAM 2.0.1, 2.0.x and 2.1.x and the result is in this branch: https://github.com/wyldckat/swak4foam/tree/OF20
The two commits with the necessary changes are here: https://github.com/wyldckat/swak4foam/commits/OF20
I'll open the bug report tomorrow and submit a patch + HG bundle on the bug tracker.
edit: bug report done: http://sourceforge.net/apps/mantisbt...iew.php?id=158
Best regards,
Bruno
akidess and elia87 like this.
Old   November 1, 2012, 04:53
akidess's Avatar
Anton Kidess
Awesome, thanks a ton! I don't quite understand why I got the unmodified version when using 'git clone https://github.com/wyldckat/swak4foam.git', and I had to do 'git checkout ae28e5f76e4c0e8666cf7eb8a35515dba7b4689f' to get the proper version, but now it seems to work (like David, I use google-git...).
By the way, I had a drive-by look at the rest of your repos, and I noticed a typo in the header of interpolateVolumeField.C: I think you intended to write "Interpolate vol*Field to surface*Field".
Old   November 1, 2012, 08:46
Bruno Santos
Ooops, sorry about that... the correct checkout command was:
git checkout OF20
This way you checkout the branch, instead of a specific commit . Although it might not work with older git versions...
I placed it in a separate branch, because that's how I usually use github and its forks: when using a fork, I always make changes in my own branches, to preserve the original branches for reference
Many thanks! It's now fixed and I left a breadcrumb in the issue tracker for that project: https://github.com/wyldckat/reconstr...ields/issues/1
Old   November 7, 2012, 09:48
Assistant Moderator
Bernhard Gschaider
Originally Posted by wyldckat View Post
Hi Anton,
Well. It is not the age. It just so happened that I only have projects with versions older and newer than 2.0
Best regards,
Bruno
I'll put in my repo ASAP (currently I'm a bit handicapped) and push it to the public repo
wyldckat likes this.
[swak4Foam] foam-extend-3.2 installing problem: swak4Foam failed to install due to Bison lxwd OpenFOAM Community Contributions 1 March 20, 2016 16:03
[swak4Foam] Error installing swak4Foam 0.2.3 on OF 2.2.2 Mojtaba.a OpenFOAM Community Contributions 2 December 7, 2013 03:32
[swak4Foam] fails in parallel with -otherTime? Phicau OpenFOAM Community Contributions 3 June 26, 2013 13:00
[swak4Foam] installation problem: "./Allwmake: ... [[: not found" Rajarshi OpenFOAM Community Contributions 8 May 13, 2013 08:05
[swak4Foam] problem on installing swak4Foam navid2 OpenFOAM Community Contributions 2 May 30, 2012 04:32
