Ekat et al. - 2023 - Hybrid LES/RANS simulations of a 90° pipe bend using ... |
Jozsef Nagy
Rep Power: 8 ![]() |
Comments and questions are welcomed on the article Ekat et al., Hybrid LES/RANS simulations of a 90° pipe bend using different CFD solvers, OpenFOAM Journal, May 2023, https://doi.org/10.51560/ofj.v3.36
Popoff
Rep Power: 4 ![]() |
Your link is not working... And I didn't found it in https://journal.openfoam.com/index.php/ofj
But I hope to read it =) |
Jozsef Nagy
Yes, it should go online tomorrow.
Now it should work. Last edited by jnagy; May 18, 2023 at 13:21. |
Rep Power: 16 ![]() |
I realise that this comment is rather late - but did you compare the results for some of the macro parameters as well? For example, it would be really interesting to compare the total pressure loss around the bend from the different CFD runs with the experimental value (or an estimate of the experimental value, from e.g. Miller, if the experimenters did not measure that).
Andreas Weissenbrunner
Rep Power: 0 ![]() |
The pressure loss have not been measured. Neither did we compare the pressure loss across the different solvers. The focus was on the velocity distribution.
Display Modes | |
[blockMesh] pipe bend mesh imperfect | jochemvandenbosch | OpenFOAM Meshing & Mesh Conversion | 9 | November 12, 2014 04:49 |
outlet profiles of LES simulation as transient inlet b.c. for LES of a bend pipe | Henny | FLUENT | 0 | March 28, 2013 04:02 |
[ICEM] Using a hybrid mesh for a simple pipe | Udio_NT | ANSYS Meshing & Geometry | 17 | October 18, 2012 14:42 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
