November 26, 2012, 19:25 |
Inconsistent number of faces
Matthias
I want to create a axisymmetric mesh consisting of a wedge-part with a block added on the outer side. I need this to get two different patches on one side, to be able to realize two velocityfields and two boundaryconditions there.
Can anyone give me advice? Thank you! Code:
Create time Creating block mesh from "/tmp/OpenFOAM/matthias-2.1.1/tutorials/incompressible/icoFoam/cavity/consta nt/polyMesh/blockMeshDict" Creating curved edges Creating topology blocks Creating topology patches Creating block mesh topology --> FOAM Warning : From function polyMesh::polyMesh(... construct from shapes...) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 888 Found 2 undefined faces in mesh; adding to default patch. Check topology Basic statistics Number of internal faces : 2 Number of boundary faces : 14 Number of defined boundary faces : 14 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list --> FOAM FATAL ERROR: Inconsistent number of faces between block pair 0 and 2 From function blockMesh::calcMergeInfo() in file blockMesh/blockMeshMerge.C at line 221. FOAM exiting |
November 28, 2012, 14:11 |
#2 | |
Abdulhaq
November 28, 2012, 18:47 |
Matthias
Thanks you for the answer!
In the meanwhile I solved the problem - it's all about the order of the vertices in the hex-blockdefinitions. Also you have to keep the same kind of order for every block, even the starting point of each patch (in the hex-def.) is important. |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 09:23 |
parallel run OpenFoam | Srinath Reddy | OpenFOAM Running, Solving & CFD | 13 | February 27, 2019 09:15 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 08:14 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
