[snappyHexMesh] Unphysical solution in simpleFoam due to meshing with SHM (I guess)
Old   September 21, 2020, 10:01
Default Unphysical solution in simpleFoam due to meshing with SHM (I guess)
Guido
Courant1 is on a distinguished road
Hey all,
I try to simulate a radial impeller case with a cylindricalInletVelocity-boundary applied on a cylinder.
In image 0 attached you can see the configuration of the stl-files.
The simulation runs well with simpleFoam and also finishes with good residuals.
During post-processing I recognised some singularities on the inlet which -as I mentioned above- is defined by cylindricalInletVelocity-boundary condition.
With visiable mesh it seems like the pressure-"stripes" are caused by the mesh.
I am usually working with openfoam 7 by openfoam.org. I also tried version 8 and v2006 by openfoam.com to rule out a version problem.
Does somebody has an idea where this singularites come from?
Thank you very much and kind regards!
Courant1 is offline   Reply With Quote
[snappyHexMesh] New multi region meshing tutorial with sHM Tobi OpenFOAM Meshing & Mesh Conversion 0 November 24, 2014 17:42
[snappyHexMesh] Multi Region Meshing with sHM marango OpenFOAM Meshing & Mesh Conversion 3 March 27, 2012 00:51
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
Question about meshing / solution scheme of CFX Coriolius CFX 8 August 1, 2004 18:39
