[snappyHexMesh] Unphysical solution in simpleFoam due to meshing with SHM (I guess) |
September 21, 2020, 10:01 |
Guido
Hey all,
I try to simulate a radial impeller case with a cylindricalInletVelocity-boundary applied on a cylinder. In image 0 attached you can see the configuration of the stl-files. 0.jpg The simulation runs well with simpleFoam and also finishes with good residuals. During post-processing I recognised some singularities on the inlet which -as I mentioned above- is defined by cylindricalInletVelocity-boundary condition. 1.jpg With visiable mesh it seems like the pressure-"stripes" are caused by the mesh. 2.jpg I am usually working with openfoam 7 by openfoam.org. I also tried version 8 and v2006 by openfoam.com to rule out a version problem. Does somebody has an idea where this singularites come from? Thank you very much and kind regards! |
[snappyHexMesh] New multi region meshing tutorial with sHM | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 24, 2014 17:42 |
[snappyHexMesh] Multi Region Meshing with sHM | marango | OpenFOAM Meshing & Mesh Conversion | 3 | March 27, 2012 00:51 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
Question about meshing / solution scheme of CFX | Coriolius | CFX | 8 | August 1, 2004 18:39 |
