[snappyHexMesh] Using STL Geometry
Like Tree3Likes
  • 2 Post By alexeym
  • 1 Post By wouter
Old   February 21, 2014, 11:37
Unhappy Using STL Geometry
Abhijit
vegaonline is on a distinguished road
Hello!
I have a Magnet having two coils. The magnet is surrounded by air. Hence we have four objects, namely, (1) Magnet core, (2) coil_1, (3) coil_2 and (4) air. I saved the geometry into STL files in ASCII. Then I made the attached single stl file. Also I have made one snappyHexMesh file. These two files have been attached. However, I do not understand how can I use snappyHexMesh.
It appears that I have to use blockMesh first as per OpenFOAM tutorial. It is tedious to write blockMesh entries for a complex geometry. Also if I use blockMesh then why should I use snappyHexMesh?
Is there any simple procedure to use STL file to make mesh for OpenFOAM analysis?
Thanks and Regards.
vegaonline is offline   Reply With Quote
Old   February 22, 2014, 16:13
Wouter van der Meer
wouter is on a distinguished road
Hello vegaonline,
I had the same trouble with shm but with Helix-OS this is easy.
Hope this helps
Wouter
wouter is offline   Reply With Quote
Old   February 24, 2014, 11:59
Abhijit
Originally Posted by wouter View Post
Hello vegaonline,
Hope this helps
Wouter
I am sorry, I could not understand how meshing application could be solved with changing an OS. SnappyHexMesh is part of OpenFOAM which I am running in OpenSUSE 13.1. I want to mesh attached STL geometry. Can you kindly illustrate?
Thanks
Old   February 24, 2014, 15:14
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
1. You need to create only surrounding geometry with blockMesh. It can be just a cuboid where all your STL surfaces reside. See $FOAM_TUTORIALS/mesh/snappyHexMesh/flange for example, initial mesh created with blockMesh is rather simple.
2. I wasn't able to view your STL file maybe because you've got several solids in one file. Save every solid in separate file and use $FOAM_TUTORIALS/mesh/snappyHexMesh/snappyMultiRegionHeater as a base for your snappyHexMeshDict.
vegaonline and TurbulentGuy like this.
alexeym is offline   Reply With Quote
Old   February 24, 2014, 15:18
Wouter van der Meer
hello vegaonline,
Helyx-OS is the free version of Helyx which is a GUI for OpenFoam. But I use it mainly as an GUI for Hsm.
In the forum there is a thread for helyx(-OS)
Hope this helps
Wouter
vegaonline likes this.
Old   February 25, 2014, 09:43
Abhijit
Originally Posted by alexeym View Post
Thanks for the advice. I could see my files in NETGEN. I saw some problems in Salome. I saved assembly geometry in ASCII stl files where each solids were saved in individual files. I thought to make them a single file by concatenating.
blockmesh, geometry, snappyhexmesh, stl file
[snappyHexMesh] What CAD software do you use to define STL surfaces? Awak OpenFOAM Meshing & Mesh Conversion 11 November 12, 2020 11:00
How to improve triangulation in my geometry ( STL) Adam_PHD CONVERGE 2 December 28, 2017 16:32
[ICEM] Work with imported STL geometry KateEisenhower ANSYS Meshing & Geometry 2 July 9, 2015 10:46
[ICEM] STL Geometry in ICEM asal ANSYS Meshing & Geometry 3 February 5, 2013 09:44
[ANSYS Meshing] need to convert a cell based geometry into STL or CGNS kamran_kibria ANSYS Meshing & Geometry 0 September 15, 2011 05:14
