[blockMesh] Non orthogonal faces
Old   February 13, 2016, 01:18
Default Non orthogonal faces
Gautham Krishnan
GauthamKrishnan is on a distinguished road
I've ran blockMesh on the following blockMeshDict file and it worked out without any warnings, but upon running checkMesh it says there are 240 non-orthogonal faces. I've gone through the blockMeshDict file subsequently and have been unable to locate the error. Could someone please help me out in this regard?
blockMeshDict:
| \\ / O peration | Version: 2.2.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 0.0001;
vertices
(0 0 0)
(300 0 0)
(0 2.5 0)
(300 2.5 0)
(0 4 0)
(300 4 0)
(0 30 0)
(300 30 0)
(0 0 0.1)
(300 0 0.1)
(0 2.5 0.1)
(300 2.5 0.1)
(0 4 0.1)
(300 4 0.1)
(0 30 0.1)
(300 30 0.1)
blocks
hex (0 1 3 2 8 9 11 10) (300 30 1) simpleGrading (1 1 1)
hex (2 3 5 4 10 11 13 12) (300 40 1) simpleGrading (1 1 1)
hex (4 5 7 6 12 13 15 14) (300 50 1) simpleGrading (1 1 1)
edges
boundary
bottomwall
type wall;
faces
(1 9 8 0)
topwall
type wall;
faces
(6 14 15 7)
leftwall
type cyclic;
neighbourPatch rightwall;
faces
(0 8 10 2)
(2 10 12 4)
(4 12 14 6)
rightwall
type cyclic;
neighbourPatch leftwall;
faces
(9 1 3 11)
(11 3 5 13)
(13 5 7 15)
frontAndBack
type empty;
faces
(1 0 2 3)
(3 2 4 5)
(5 4 6 7)
(8 9 11 10)
(10 11 13 12)
(12 13 15 14)
mergePatchPairs
GauthamKrishnan is offline   Reply With Quote
Old   February 14, 2016, 13:48
Gautham Krishnan
I think the non-orthogonality error might be due to cyclic boundary conditions on leftwall and rightwall. Can someone help me out with this?
Old   February 14, 2016, 14:57
Mikko
Flowkersma is on a distinguished road
OpenFOAM 2.4.x and 3.0.0 did not give any errors with your blockMeshDict file. If you want to see which faces cause the error, run
foamToVTK -faceSet nonOrthogonalFaces
and open the corresponding file inside VTK directory.
Best regards,
Mikko
Flowkersma is offline   Reply With Quote
Old   February 14, 2016, 21:14
Gautham Krishnan
I've been using openFOAM 2.2.0 and checkmesh gives me this error. I've checked which faces are in non-orthogonal sets file, it's the right wall and the left wall,the ones with the cyclic boundary conditions. Is there a way to fix this?
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 09:23
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) AndreP STAR-CCM+ 10 August 2, 2018 07:48
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 10:58
