April 15, 2008, 05:41 |
Error while blockMesh
Sebastian
Rep Power: 17 |
i have a little problem. I created a 3d-geometrie, but when i use blockMesh, the following error is reported: #0 Foam::error::printStack(Foam:stream&) in "/home/sebastian/OpenFOAM/OpenFOA M-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/sebastian/OpenFOAM/OpenFOAM-1.4.1 /lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xffffe420] #3 Foam::wedgePolyPatch::initTransforms() in "/home/sebastian/OpenFOAM/OpenFOAM -1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam::wedgePolyPatch::wedgePolyPatch(Foam::word const&, int, int, int, Foam: :polyBoundaryMesh const&) in "/home/sebastian/OpenFOAM/OpenFOAM-1.4.1/lib/linuxG ccDPOpt/libOpenFOAM.so" #5 Foam::polyPatch::addwordConstructorToTable<foam::w edgepolypatch>::New(Foam:: word const&, int, int, int, Foam::polyBoundaryMesh const&) in "/home/sebastian/O penFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #6 Foam::polyPatch::New(Foam::word const&, Foam::word const&, int, int, int, Fo am::polyBoundaryMesh const&) in "/home/sebastian/OpenFOAM/OpenFOAM-1.4.1/lib/lin uxGccDPOpt/libOpenFOAM.so" #7 Foam::polyMesh::polyMesh(Foam::IOobject const&, Foam::Field<foam::vector<dou> > const&, Foam::List<foam::cellshape> const&, Foam::List<foam::list<foam::f> > const&, Foam::List<foam::word> const&, Foam::List<foam::word> const&, Foa m::word const&, Foam::List<foam::word> const&, bool) in "/home/sebastian/OpenFOA M/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #8 Foam::blockMesh::createTopology(Foam::IOdictionary &) in "/home/sebastian/Ope nFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/blockMesh" #9 Foam::blockMesh::blockMesh(Foam::IOdictionary&) in "/home/sebastian/OpenFOAM /OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/blockMesh" #10 main in "/home/sebastian/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccD POpt/blockMesh" #11 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #12 Foam::regIOobject::readIfModified() in "/home/sebastian/OpenFOAM/OpenFOAM-1 .4.1/applications/bin/linuxGccDPOpt/blockMesh" Floating point exception (core dumped) Can anyone help me? What can i do, to fix this problem? Greatings fightingfalcon23 |
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 | bjdarrer | OpenFOAM Installation | 7 | August 25, 2020 19:15 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
[blockMesh] External flow around cube with blockMesh | Woody8 | OpenFOAM Meshing & Mesh Conversion | 0 | March 31, 2015 14:54 |
[blockMesh] set of xyz data in blockMesh | psk | OpenFOAM Meshing & Mesh Conversion | 12 | August 27, 2013 08:37 |
Blockmesh cavity error message | tonitoney | OpenFOAM Installation | 2 | March 17, 2008 11:59 |
