[Gmsh] ChannelOodles with gmsh
Old   March 17, 2008, 10:20
Default ChannelOodles with gmsh
OpenFOAM Newbie
lofty is on a distinguished road
Hi Guys
I wanna simulate a flow in channel with number of obstcales inside. Inlet and outlet faces are not same! Is it possible to build an OpenFOAM cyclic geometry out of a gmsh mesh? Thanks
lofty is offline   Reply With Quote
Old   March 18, 2008, 06:39
Default Hi May be no one understood
OpenFOAM Newbie
Hi
May be no one understood what i was trying to say. Let me put it another way. Can i use cyclic BC in OF on a domain that has walls/obstcales inside. Thank you in advance for your reply
Old   March 18, 2008, 07:10
Default Yes. You can. But your periodi
diablo80@web.de
sampaio is on a distinguished road
Yes. You can. But your periodic patches must be consistent.
sampaio is offline   Reply With Quote
Old   March 18, 2008, 07:31
Default When you say "consistent", you
OpenFOAM Newbie
When you say "consistent", you mean opposite faces must be geometrically consistent right?
Thank you Luiz
OpenFOAM Newbie
Old   March 18, 2008, 10:06
Default Yes, geometrically consistent.
diablo80@web.de
Good luck,
luiz
Old   March 18, 2008, 12:04
Default Is it gone be possible to use
OpenFOAM Newbie
Is it gone be possible to use blockMesh if my patches are same on opposite sides. Please note i want to use channelOodles solver. I have several 3D walls inside my channel.
Cyclic BC works fine when i have no wall inside the channel but as soon as i place a wall inside the channel it gives me an error. Any idea why is this happening? Thank you very much luiz
OpenFOAM Newbie
Old   March 18, 2008, 16:19
Default You have partial walls, right?
diablo80@web.de
You have partial walls, right? I dont see any problem with that, and yes, you can use channelOodles.
Did you try checkMesh?
Good luck,
luiz
Old   April 16, 2008, 16:44
Default I'm using a gmsh grid, too, bu
Scott Ripplinger
sripplinger is on a distinguished road
I'm using a gmsh grid, too, but I'm having issues getting the cyclic boundary conditions to work. The grid just has a rectangular inlet and outlet with walls on the top and bottom. I want the left and right sides to be cyclic, but when I try running icoFoam I get errors. I've also tried createPatches, but that fails, too.
sripplinger is offline   Reply With Quote
[Gmsh] Converting gmsh to OpenFoam Friendly OpenFOAM Meshing & Mesh Conversion 3 June 26, 2018 05:46
[Gmsh] Insatlling gmsh from the source code-issue? CFD-Lover OpenFOAM Meshing & Mesh Conversion 20 June 12, 2018 06:39
[Gmsh] Cgns support for gmsh robyTKD OpenFOAM Meshing & Mesh Conversion 1 July 13, 2016 11:27
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
