[Other] Creating large meshes (>10,000,00) in parallel
Old   April 16, 2012, 13:01
Post Creating large meshes (>10,000,00) in parallel
fontania is on a distinguished road
Fellow members and users of OpenFOAM,
I am having problems creating large meshes (greater than 10,000,000) elements. No surprise I am running out of memory on a single computer. I am looking to create a mesh up to 100,000,000 elements. The domain is simply a unit 1x1x1 cube. Does anyone have a tested procedure for parallel discretization or refinement?
Thanks in advance!
fontania is offline   Reply With Quote
Old   April 16, 2012, 14:26
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
How can your domain be a 1x1x1 cube?
Have you tried with decomposePar and then running sHM in parallel with mpirun?
lovecraft22 is offline   Reply With Quote
Old   April 16, 2012, 15:04
1x1x1 cube: I am doing a scaling analysis on a cluster to understand how many processors to run different problem sizes. My base case is the incompressible/icoFOAM/cavity tutorial.
The problem I will eventually be solving is airflow within a large building. After the scaling analysis do I...
1. Create a STL file of the domain
2. Use blockMesh for a basic overlapped representation.
3. Use decomposePar to decompose the initial mesh to the number of processors I plan on running the simulation
4. Use snappyHexMesh in parallel to create the actual domain discretization.
Thanks for the quick reply.
Old   April 16, 2012, 15:29
lore
Sorry, I'm missing the point then… The question is…?
Old   April 16, 2012, 16:14
Retired Super Moderator
Bruno Santos
Quick answer: see the tutorial "./incompressible/simpleFoam/turbineSiting"
Error running simpleFoam in parallel Yuby OpenFOAM Running, Solving & CFD 14 October 7, 2021 04:38
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 16:49
Creating large enclosure containing many persons Michael CFX 0 January 21, 2009 05:42
[blockMesh] Tutorial for Creating Simple 3D Meshes jonlemur OpenFOAM Meshing & Mesh Conversion 4 August 8, 2007 13:20
Large 3D tetrahedral meshes Aldo Bonfiglioli Main CFD Forum 4 August 27, 1999 03:33
