August 19, 2016, 05:59 |
Delete cells from inside a mesh.stl
jorge rodriguez
Rep Power: 17 |
Hi Pals,
I'm trying to figure out how to delete cells inside the hull mesh which is in stl format see Fig 2, The mesh around the hull has been created with Gmsh see Fig. 1. What software should I use ?. I was reading that SHM will be suitable to fix the problem but any help or suggestion is very welcome. the point of this project is to create a numerical tank and run resistance around the hull in calm water Cheers |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel | colinB | OpenFOAM Meshing & Mesh Conversion | 14 | December 12, 2018 08:07 |
[blockMesh] Create internal faces as patch in blockMesh | m.delta68 | OpenFOAM Meshing & Mesh Conversion | 14 | July 12, 2018 14:43 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
[snappyHexMesh] Delete cells with special volume | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | May 30, 2016 09:45 |
