[snappyHexMesh] Snappy Hex Mesh problems
Old   April 3, 2011, 23:26
Default Snappy Hex Mesh problems
Wesley
likefry is on a distinguished road
Hi all,
I'm having some problems with snappyhexmesh in openfoam in creating a new shape.
I'm trying to model a 3d boat rudder i've made in solidworks. I created the STL file in solidworks but i can't get it to create the mesh.
when i run snappyhexmesh it created a new layer but its empty.
i've used the motorbike example as a template and no matter what i do i can't get it to work.
Here is the SHM file.
Any help would be greatly appreciated.
I know i'm getting an empty mesh as when i run checkmesh it says the size is 0 cells.
Wes
likefry is offline   Reply With Quote
Old   April 4, 2011, 03:52
colinB is on a distinguished road
Hi
one of the problems you have, is that you have different names for the same things in your sHMD file:
airfoil1rudder =! rudderPatch
look for these two above mentioned names in your file and ensure that they are the same.
This should help to fix your problem.
Finally another remark:
For troubles with sHM there is a separate Forum so it is more convenient to use that.
regards
Colin
colinB is offline   Reply With Quote
Old   September 22, 2011, 04:14
Miguel
mfiandor is on a distinguished road
where is that separate forum for SHMD?
really keen on it
mfiandor is offline   Reply With Quote
Old   September 22, 2011, 06:49
Elvis
elvis will become famous soon enough
http://www.cfd-online.com/Forums/ope...snappyhexmesh/
you also might have a look at Discretizer
http://www.discretizer.org/
=>Discretizer-Setup gives some aid dealing with SHM
http://www.discretizer.org/files/boxdialog.jpg
elvis is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[snappyHexMesh] About Non-conformal Mesh, Snappy Hex Mesh Chaitanya2811 OpenFOAM Meshing & Mesh Conversion 0 March 25, 2019 09:03
[snappyHexMesh] Snappy Hex Mesh - issue with smoothness of the model edges olek.warc OpenFOAM Meshing & Mesh Conversion 1 August 31, 2018 11:31
[snappyHexMesh] Pure hex mesh with snappy alf23 OpenFOAM Meshing & Mesh Conversion 17 February 17, 2013 14:24
[blockMesh] BlockMesh number internal faces and boundary ynos OpenFOAM Meshing & Mesh Conversion 6 December 13, 2011 05:36
