[snappyHexMesh] SnappyHexMesh
Old   October 5, 2009, 10:32
Default SnappyHexMesh
Samuele Z
samiam1000 is on a distinguished road
Hi there,
Im trying to use snappyHexMesh to generate a mesh aroound an airplane.
But I get an error. I copy the error I get, below and I attach the 3 files I am modifying to run snappyHexMesh.
Could someone help, please?
Thanks a lot,
Samuele.
samiam@einstein:~/OpenFOAM/Pingus_project/pingus$ snappyHexMesh -overwrite
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 1.6-53b7f692aa41
Exec : snappyHexMesh -overwrite
Date : Oct 03 2009
Time : 11:00:15
Host : einstein
PID : 7589
Case : /home/samiam/OpenFOAM/Pingus_project/pingus
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 500
Read mesh in = 4.25 s
Overall mesh bounding box : (-5000 -17000 -5000) (25000 17000 9000)
Relative tolerance : 1e-06
Absolute matching distance : 0.0474552
Reading refinement surfaces.
Read refinement surfaces in = 1.09 s
Reading refinement shells.
Refinement level 4 for all cells inside refinementBox
Read refinement shells in = 0 s
Setting refinement level of surface to be consistent with shells.
Checked shell refinement in = 0.01 s
Determining initial surface intersections
Incorrect cellLevel or pointLevel size.
Number of cells in mesh:343000 does not equal size of cellLevel:155756
Number of points in mesh:357911 does not equal size of pointLevel:168084#0 Foam::error:rintStack(Foam::Ostream&) in "/home/samiam/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/samiam/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Foam::hexRef8::hexRef8(Foam:olyMesh const&, Foam::List<int> const&, Foam::List<int> const&, Foam::refinementHistory const&) in "/home/samiam/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libdynamicMesh.so"
#3 Foam::meshRefinement::meshRefinement(Foam::fvMesh& , double, bool, Foam::refinementSurfaces const&, Foam::shellSurfaces const&) in "/home/samiam/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libautoMesh.so"
#4 main in "/home/samiam/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/snappyHexMesh"
#5 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#6 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122
From function hexRef8::hexRef8(const polyMesh&, const labelList&, const labelList&, const refinementHistory&)
in file polyTopoChange/polyTopoChange/hexRef8.C at line 1912.
FOAM aborting
Aborted
samiam1000 is offline   Reply With Quote
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 06:01
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 02:54
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 02:55
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? klausb OpenFOAM Meshing & Mesh Conversion 1 March 7, 2015 11:55
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 02:09
