October 5, 2009, 10:32 |
SnappyHexMesh
Samuele Z
Rep Power: 18 |
Hi there,
Im trying to use snappyHexMesh to generate a mesh aroound an airplane. But I get an error. I copy the error I get, below and I attach the 3 files I am modifying to run snappyHexMesh. Could someone help, please? Thanks a lot, Samuele. Code: samiam@einstein:~/OpenFOAM/Pingus_project/pingus$ snappyHexMesh -overwrite /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6-53b7f692aa41 Exec : snappyHexMesh -overwrite Date : Oct 03 2009 Time : 11:00:15 Host : einstein PID : 7589 Case : /home/samiam/OpenFOAM/Pingus_project/pingus nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 500 Read mesh in = 4.25 s Overall mesh bounding box : (-5000 -17000 -5000) (25000 17000 9000) Relative tolerance : 1e-06 Absolute matching distance : 0.0474552 Reading refinement surfaces. Read refinement surfaces in = 1.09 s Reading refinement shells. Refinement level 4 for all cells inside refinementBox Read refinement shells in = 0 s Setting refinement level of surface to be consistent with shells. Checked shell refinement in = 0.01 s Determining initial surface intersections ----------------------------------------- Incorrect cellLevel or pointLevel size. Number of cells in mesh:343000 does not equal size of cellLevel:155756 Number of points in mesh:357911 does not equal size of pointLevel:168084#0 Foam::error:rintStack(Foam::Ostream&) in "/home/samiam/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/samiam/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Foam::hexRef8::hexRef8(Foam:olyMesh const&, Foam::List<int> const&, Foam::List<int> const&, Foam::refinementHistory const&) in "/home/samiam/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libdynamicMesh.so" #3 Foam::meshRefinement::meshRefinement(Foam::fvMesh& , double, bool, Foam::refinementSurfaces const&, Foam::shellSurfaces const&) in "/home/samiam/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libautoMesh.so" #4 main in "/home/samiam/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/snappyHexMesh" #5 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #6 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122 From function hexRef8::hexRef8(const polyMesh&, const labelList&, const labelList&, const refinementHistory&) in file polyTopoChange/polyTopoChange/hexRef8.C at line 1912. FOAM aborting Aborted |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 06:01 |
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing | peterhess | OpenFOAM Meshing & Mesh Conversion | 2 | January 3, 2018 02:54 |
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. | jasv | OpenFOAM Meshing & Mesh Conversion | 4 | May 10, 2016 02:55 |
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? | klausb | OpenFOAM Meshing & Mesh Conversion | 1 | March 7, 2015 11:55 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 02:09 |
