[Commercial meshers] fluentMeshToFoam: "fluent patch type shadow not recognised"
Old   July 27, 2009, 11:21
Unhappy fluentMeshToFoam: "fluent patch type shadow not recognised"
Stefan
preibie is on a distinguished road
Hallo,
I want to convert a Fluent msh File to OpenFoam. By using fluentMeshToFoam is a mistake (show below). Have anybody an Idea how I can concert a Fluent msh file to openFoam.
Thanks
|  \\    /   O peration     | Version:  1.5                                   |
|   \\  /    A nd           | Web:      http://www.OpenFOAM.org               |
Exec   : fluentMeshToFoam brick.msh
Date   : Jul 27 2009
Time   : 17:15:35
Host   : Fluent64-2
PID    : 29859
Case   : /home/preibisch/OpenFOAM/preibisch-1.5/run/brick
nProcs : 1
Create time
Dimension of grid: 3
Number of points: 15410
Reading points
number of faces: 155152
Reading mixed faces
Reading mixed faces
8(c6d 18d8 4 3Reading mixed faces
Reading mixed faces
Reading mixed faces
Number of cells: 74714
Other readCellGroupData: 2 1 123da 1 2
Reading uniform cells
Read zone1:2 name:fluid patchTypeID:fluid
Reading zone data
Read zone1:3 name:periodic.1_shadow patchTypeID:shadow
Reading zone data
Read zone1:4 name:periodic.1 patchTypeID:periodic
Reading zone data
Read zone1:5 name:out patchTypeID:wall
Reading zone data
Read zone1:6 name:inner patchTypeID:wall
Reading zone data
Read zone1:8 name:default-interior patchTypeID:interior
Reading zone data
FINISHED LEXING
dimension of grid: 3
Creating shapes for 3-D cells
Building patch-less mesh...--> FOAM Warning :
    From function polyMesh::polyMesh(... construct from shapes...)
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 576
    Found 11448 undefined faces in mesh; adding to default patch.
done.
Building boundary and internal patches.
Creating patch 0 for zone: 3 start: 1 end: 3180 type: shadow name: periodic.1_shadow
fluent patch type shadow not recognised.#0  Foam::error::printStack(Foam::Ostream&) in "/home/preibisch/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1  Foam::error::abort() in "/home/preibisch/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#2  main in "/home/preibisch/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/fluentMeshToFoam"
#3  __libc_start_main in "/lib64/libc.so.6"
#4  __gxx_personality_v0 in "/home/preibisch/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/fluentMeshToFoam"
    From function fluentToFoam::main(int argc, char *argv[])
    in file fluentMeshToFoam.L at line 1337.
FOAM aborting
Last edited by wyldckat; April 30, 2017 at 12:31. Reason: Added [CODE][/CODE] markers
preibie is offline   Reply With Quote
Old   July 27, 2009, 11:38
Julien Schaguene
Schag is on a distinguished road
it seems that OpenFOAM doesn't recognize the type Shadow from Fluent (Gambit?).
You can have a look at lines 1260 to 1340 of fluentMeshToFoam.L (thank you Henrik to make me open this file earlier today), shadow is not an option for a patch from fluent to openFoam.
What does "shadow" means for you? Is it an internal face, a patch, fan, wall...?
Regards,
Julien
Schag is offline   Reply With Quote
Old   July 28, 2009, 02:54
Stefan
it is an internal wall i think, but how can I fix that problem?
Old   July 28, 2009, 03:11
Julien Schaguene
First, I don't think fluentMeshToFoam keeps internal faces (it didn't ever work for me, but I have to confess that I was not very persistent). Do you really need them?
Then, in Gambit, when creating boundary conditions, just choose another type than shadow (in this case, internal for example). If you don't need them, just don't mark them as boundary conditions.
Hope it helps...
Julien
Old   July 28, 2009, 04:00
Stefan
I found the "mistake": when you define a pair of two walls for periodic boundary conditions on gambit one of this two walls is a shadow wall. I defined them to a simple wall and fluentMeshToFoam run without problems.
But how I define a periodic boundary condition?
Old   July 28, 2009, 04:02
Julien Schaguene
Are you speaking about cyclic BC?
Old   July 28, 2009, 04:19
Stefan
I think yes. When a fluid element fly out of the domain by crossing one of this two walls. He comes in the domain again by crossing the other wall. Is this the definition for cyclic BC?
Old   July 28, 2009, 04:31
Julien Schaguene
I'm not familiar with cyclic BC, but I think this is the definition yes.
Maybe you should take a look there:
http://www.cfd-online.com/Forums/ope...-boundary.html
This topic seems to deal with your problem. I cannot do much more, sorry, I did not use cyclic BC yet. Good luck.
Old   October 4, 2012, 15:13
sivakumar selvaraju
sivakumar is on a distinguished road
Send a message via Skype™ to sivakumar
Hi there,
I am trying to mesh the fan passage in gambit.
I dont know what is the problem in the mesh, its giving the following error.
Create time
Number of points: 808911
Reading points
number of faces: 2358500
Reading mixed faces
Reading mixed faces
8(fa1 1f40 4 3Reading mixed faces
Reading mixed faces
8(4651 6d60 6 5Reading mixed faces
Reading mixed faces
Reading mixed faces
Reading mixed faces
Reading mixed faces
Reading mixed faces
Reading mixed faces
Reading mixed faces
Reading mixed faces
Number of cells: 775000
Other readCellGroupData: 2 1 bd358 1 4
Reading zone data
Read zone1:3 nameeriodic_1_shadow patchTypeID:shadow
Reading zone data
Read zone1:4 nameeriodic_1 patchTypeIDeriodic
Reading zone data
Read zone1:5 nameeriodic_2_shadow patchTypeID:shadow
Reading zone data
Read zone1:6 nameeriodic_2 patchTypeIDeriodic
Reading zone data
Read zone1:7 name:top_3 patchTypeID:wall
Reading zone data
Read zone1:8 name:top_2 patchTypeID:wall
Reading zone data
Read zone1:9 name:top_1 patchTypeID:wall
Reading zone data
Read zone1:10 name:center_2 patchTypeID:wall
Reading zone data
Read zone1:11 name:center_1 patchTypeID:wall
Reading zone data
Read zone1:12 name:fan patchTypeID:fan
Reading zone data
Read zone1:13 nameutlet patchTypeIDressure-outlet
Reading zone data
Read zone1:14 name:inlet patchTypeID:velocity-inlet
Reading zone data
Read zone1:16 name:default-interior patchTypeID:interior
Reading zone data
FINISHED LEXING
From function polyMesh:olyMesh(... construct from shapes...)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 614
Found 67000 undefined faces in mesh; adding to default patch.
done.
Creating patch 0 for zone: 3 start: 1 end: 4000 type: shadow name: periodic_1_shadow
--> FOAM FATAL ERROR:
in file fluentMeshToFoam.L at line 1344.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/cerecam/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/cerecam/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
in "/home/cerecam/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/bin/fluentMeshToFoam"
#3 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Aborted (core dumped)
I dont know what is the shadow, I didnt define anything like that.
can you please help me sort out this issue.
thanks and regards,
Siva
sivakumar is offline   Reply With Quote
Old   October 4, 2012, 18:02
Francesco
Bombolati is on a distinguished road
Hi Siva, in my mesh the shadow patch was a patch that was coupled with an other one. For example you design a cylinder,to reduce the dimension of the file you do a clove of this cylinder. Now you have two sides that were the same surface before you do the clove,for example L1. In the mesher (as gambit) you assign a periodic boundary condition to L1 and its "brother". When you convert the mesh, OF sees L1 and L1_shadow. I hope that this hint will be useful.
Bombolati is offline   Reply With Quote
Old   October 5, 2012, 03:44
sivakumar selvaraju
Hi Bombolati,
Thanks for your reply, i got the information regarding the shadow.
If it gives the full converted mesh then, i can edit the necessary files. but now its not converting the whole mesh, its giving the fatal error in between and it stopped converting the mesh.
see the message,
FOAM aborting
what should i do now? please give me your idea.
Thanks and regards,
Siva
Old   October 5, 2012, 03:54
blacksquirrel is on a distinguished road
Hello Siva,
You can try to simplify your boundary conditions in gambit, like using only velocity inlet, pressure outlet and wall for everything else (e.g. periodic boundarys).
And after you converted the mesh with Fluent(3D)MeshToFoam you can use the createPatch utility to create the patches you need from your "walls".
blacksquirrel is offline   Reply With Quote
Old   October 5, 2012, 04:01
sivakumar selvaraju
Thanks, nice idea. i will try now, then i will post result
thanks.
Siva
Old   October 5, 2012, 06:47
sivakumar selvaraju
Hi blacksquirrel,
As per you idea, I have generated the mesh with wall boundary condition.
Now i wan to use the createPatch utility, can you please explain it.
In which folder i need to execute the command?
Old   October 5, 2012, 07:18
Hello Siva,
You execute createPatch from your "case" folder. It reads everything from the createPatchDict (http://openfoamwiki.net/index.php/CreatePatch) in the "case"/system folder.
What kind of boundaries do you want to create? Cyclic boundaries? I explained it in this thread:
http://www.cfd-online.com/Forums/ope...patchdict.html
Old   October 5, 2012, 08:34
Retired Super Moderator
Bruno Santos
Greetings to all!
FYI, I've moved that thread to here: http://www.cfd-online.com/Forums/ope...patchdict.html - I think it's easier to find it in the future, if it's located in the right sub-forum
Best regards,
Bruno
Old   October 5, 2012, 10:28
sivakumar selvaraju
Hi there,
I have converted the .msh in to foam.
I got 2 errors,
firstly as follows,
face 6439 area does not match neighbour by 0.0103693% -- possible face ordering problem.
patch:OLR0 my area:0.000199448 neighbour area:0.000199427 matching tolerance:0.0001
Mesh face:1370739 fc0.0966635 -0.0215988 0.729129)
Neighbour fc0.0967883 -0.5304 0.500736)
If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file.
Rerun with cyclic debug flag set for more information.
then I have increased the matchTolerance 0.0001 to 0.001
then executed paraFoam
after that I am getting the error as follows,
More than six unsigned transforms detected:
6(((0 0 0) (1 1.57813e-06 -0.000193506 -0.000137946 0.707107 -0.707107 0.000135714 0.707107 0.707107) 1) ((0 0 0) (0.999999 3.64383e-05 -0.00152133 -0.00110151 0.707109 -0.707104 0.00104998 0.707105 0.707108) 1) ((0 0 0) (0.999996 7.7863e-05 -0.00275828 -0.00200544 0.707113 -0.707098 0.00189536 0.7071 0.707111) 1) ((0 0 0) (0.999992 0.000140037 -0.00401223 -0.00293604 0.70712 -0.707087 0.00273811 0.707093 0.707115) 1) ((0 0 0) (1 -0.000137946 0.000135714 1.57813e-06 0.707107 0.707107 -0.000193506 -0.707107 0.707107) 1) ((0 0 0) (0.999999 -0.00110151 0.00104998 3.64383e-05 0.707109 0.707105 -0.00152133 -0.707104 0.707108) 1))
From function void Foam::globalIndexAndTransform::determineTransforms ()
in file primitives/globalIndexAndTransform/globalIndexAndTransform.C at line 225.
can you guys help me.
Thanks,
Siva
Old   October 8, 2012, 03:40
hello Siva,
I assume these errors occur while using the createPatch utility?
Then look in your createPatchDict. What is written in the "transform" options?
(e.g.
transform rotational;
rotationAxis (1 0 0);
rotationCentre (0 0 0); )
You maybe don't need to transform anything, so you can delete/comment the transform options.
Old   October 8, 2012, 07:10
sivakumar selvaraju
Dear blacksquirrel,
I am giving you the createPatchDict and my boundary file.
please have a look.
my createPatchDict :
// Patches to create.
patches
// Name of new patch
name ILR0;
// Dictionary to construct new patch from
patchInfo
type cyclic;
neighbourPatch ILR1;
// Optional non-default tolerance to be able to define cyclics
// on bad meshes
matchTolerance 1E-3;
// How to construct: either from 'patches' or 'set'
constructFrom patches;
// If constructFrom = patches : names of patches. Wildcards allowed.
patches (ILR_shadow);
name ILR1;
patchInfo
type cyclic;
neighbourPatch ILR0;
// on bad meshes
patches (ILR);
name OLR0;
patchInfo
type cyclic;
neighbourPatch OLR1;
// on bad meshes
patches (OLR_shadow);
name OLR1;
patchInfo
type cyclic;
neighbourPatch OLR0;
// on bad meshes
patches (OLR);
my boundary file is:
FoamFile
version 2.0;
format ascii;
class polyBoundaryMesh;
location "1/polyMesh";
object boundary;
12
fan
type wall;
nFaces 2800;
startFace 1357300;
top2
type wall;
nFaces 5600;
startFace 1360100;
top1
type wall;
nFaces 800;
startFace 1365700;
top0
type wall;
nFaces 2800;
startFace 1366500;
center1
type wall;
nFaces 5600;
startFace 1369300;
center0
type wall;
nFaces 2800;
startFace 1374900;
outlet
type patch;
nFaces 2000;
startFace 1377700;
inlet
type patch;
nFaces 2000;
startFace 1379700;
ILR0
type cyclic;
nFaces 3500;
startFace 1381700;
matchTolerance 0.001;
ILR1
type cyclic;
nFaces 3500;
startFace 1385200;
OLR0
type cyclic;
nFaces 7000;
startFace 1388700;
OLR1
type cyclic;
nFaces 7000;
startFace 1395700;
please help me to sort out this problem,
And what are the further steps I need to follow?
Thank you,
Siva
Old   October 8, 2012, 07:41
I'm sorry, for me those two files look fine. Can you post a picture of your gambit mesh? Your error message said, that ILR and ILR_shadow (or OLR with shadow) doesn't match exactly. I had a similar error once and had to rotate one patch to match the other one.
reactingMultiphaseEulerFoam tonnykz OpenFOAM Running, Solving & CFD 2 June 15, 2020 02:09
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 13:48
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
[Commercial meshers] Fluent msh and cyclic boundary cfdengineering OpenFOAM Meshing & Mesh Conversion 48 January 25, 2013 03:28
[swak4Foam] Air Conditioned room groovyBC Sebaj OpenFOAM Community Contributions 7 October 31, 2012 14:16
