[Commercial meshers] Errors in polyMesh folder after renumberMesh |
April 24, 2018, 13:21 |
Paul
Rep Power: 8 |
Hello everybody,
I used Pointwise 18.1 to generate a hybrid mesh for a solar updraft tower. I have 5 blocks, and checkMesh shows that everything is ok. After running renumberMesh -overwrite, the faces, neighbour, owner, and points files have NUL in all lines. Do you know what could be the reason, and how to solve it? Here is my controlDict file PHP Code:
Paul |
April 24, 2018, 15:34 |
Paul
Rep Power: 8 |
Hello again,
This is solved. The problem is that the writeFormat is set to binary, so I could run in my pc, but then when I tried to run in a cluster, I got some errors. Now I have changed to ascii, and it is ok. Thanks to Travis Carrigan |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 10:08 |
InterFoam negative alpha | karasa03 | OpenFOAM | 7 | December 12, 2013 03:41 |
