[Commercial meshers] FluentMeshToFoam Cannot find a single face in the mesh which uses vertices
Old   February 29, 2008, 11:24
Default FluentMeshToFoam Cannot find a single face in the mesh which uses vertices
Francesco Boschetto
francesco_b is on a distinguished road
Hi All,
sometimes when I build my mesh, using HyperMesh and then exporting it as a fluent mesh (file .cas) ) I receive this error message:
--> FOAM FATAL ERROR : Problem : cannot find a single face in the mesh which uses vertices 4(80040 80037 80039 80041)
From function findFace(const primitiveMesh&, const face&)
in file fluentMeshToFoam.L at line 855.
FOAM exiting
Can you tell me what to do? I checked the mesh and everything seems to be ok
Thanks in advance
Francesco
francesco_b is offline   Reply With Quote
Old   February 29, 2008, 11:45
Default I found the error I have bu
Francesco Boschetto
I found the error
I have built the mesh with Hypermesh 7, opened with the 8 and converted, if I build it in the 8 there is no error.
I hope this could be useful to someone else
Regards
Old   May 20, 2009, 04:12
Hasselhoff is on a distinguished road
Hi everyone. I received the same error.
The Mesh was generated with gambit and cannot be converted to Foam. I included some virtual edges/ points in order to mesh the interfaces.
The Mesh seems to be ok.
Thank you,
Michael
Hasselhoff is offline   Reply With Quote
Old   October 1, 2009, 08:10
Milos Stanic
milos is on a distinguished road
Originally Posted by francesco_b View Post
I found the error
Regards
Could you please explain in more details what is exactly 'Hypermesh 7' and what does it do in the first place. I'm having same serious trouble with 'lost vertices' on every mesh that I generate.
Thanks a million!
milos is offline   Reply With Quote
Old   March 19, 2018, 08:37
JSR
Jaijeet
JSR is on a distinguished road
I am also facing the same issue....Is this because of version of Gambit I am using, any solution will be highly appreciated.
Thankyou
JSR is offline   Reply With Quote
Old   December 19, 2018, 08:15
Emre
ordinary is on a distinguished road
Unfortunately, I have same problem. It is a real SHAME to see this message after trying hard on mesh.
Regards,
Emre
ordinary is offline   Reply With Quote
Old   March 5, 2019, 04:10
Julien
holt78 is on a distinguished road
I had the same issue a while ago.
The error was that i had a 2D mesh but while exporting my msh file, in the export option the 3D Model box was checked... Checking the 2D box solve the issue.
Another problem was that i had an internal wall BC but openfoam can't handle 1D wall elements inside the domain. So i had to give a surface to that wall by making holes in the domain.
Hope it will help.
holt78 is offline   Reply With Quote
Old   April 18, 2019, 15:21
Panos Koniavitis
PanosK is on a distinguished road
Hi there guys, I am trying to create an *.msh file with Gmsh and then import this in openfoam. When I create the msh file and run fluentMeshToFoam I get
FINISHED LEXING
dimension of grid: 0
Creating shapes for 3-D cells
Building patch-less mesh...done.
Building boundary and internal patches.
Writing mesh... to "constant/polyMesh" done.
End
And there as you can imagine no mesh. Apparently I create something wrong. I am trying to find an .msh file available to see where the mistake might be and actually how it should look but haven't made. Does anyone have anything simple available just to see the structure of the file?
--------UPDATE-----------
I just found out that I need to "export" the mesh on Gmsh instead of just saving.
PanosK is offline   Reply With Quote
Old   December 2, 2020, 02:57
Ram
guptaram is on a distinguished road
I am facing similar problem (cannot find a single face in the mesh which uses vertices 345968 5522 33610) in foam extend 4.0, and mesh is generated in Ansys 2020R2. Can anyone suggest me, how I can resolve this ASAP?
Thanks,
Best Regards,
Ram
guptaram is offline   Reply With Quote
Simulating fire in a tunnel luca1992 OpenFOAM 14 August 16, 2017 13:50
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
