[snappyHexMesh] Refinement edges
Old   July 6, 2012, 06:28
Default Refinement edges
Vincenzo Santoro
vinezio is on a distinguished road
Hi Foamers,
the figure shows the inlet and outlet of my cooler. I would to ask you how i can obtain the similar result in proximity of edges. The concentric layers are important to study turbulence model. This geometry comes from fluent export. Any ideas??
vinezio is offline   Reply With Quote
Old   July 7, 2012, 06:04
Jan
SirWombat is on a distinguished road
Send a message via Skype™ to SirWombat
Hi Vincenzo,
your "snappyHexMeshDict" looks good. If your layer cells don't get filtered by the quality settings, then this should be fine. (You could switch off all quality controls and check what it looks like then. Then carefully raise quality controls until "checkMesh" gives you an OK ... << see this post)
So why are there no layer cells?:
Assuming, that the images you posted are the full geometry, then here is a possible answer: snappyHexMesh cannot make layer cells orthogonal to a boundary. They will always start growing at a boundary edge. So unless you will cut your geometry in half in paraview/parFoam you will not see, whether there are any layers and what they look like. You could use a cutting plane for that, or better "extractedCellsByRegion".
SOLUTION:
AFAIK there is no solution for that problem. Though it might be possible to extend the geometry at the boundary, then snappyHexMesh the extended version of your mesh and afterwards cut the extended part off. But this is only a idea ... I never tried it.
Greets,
Jan
~~~_/)~~~
SirWombat is offline   Reply With Quote
Old   July 10, 2012, 19:14
Vincenzo Santoro
Thanks so much Jan!! I'm tried several options. We'll inform about the progress.
Greets,
vinezio
Old   July 13, 2012, 13:58
Jan
Hi Vincenzo,
I just came across a possible solution:
If you set your "inlet"-patch to patch type "empty" in your blockMeshDict then snappyHexMesh will give you orthogonal cell layers. No need for cutting!
e.g.
    inlet
        type empty;
        faces
            (0 4 7 3)
then run blockMesh and SHM.
Afterwards you will need to change the patch type in the "boundary"-file located under "constant/polyMesh/" to type "patch".
Here's the link for reference: https://sites.google.com/site/snappy.../cylinder-case
Greets, Jan
~~~_/)~~~
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 09:12
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 01:37
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 17:12
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
