February 7, 2011, 14:56 |
Channel with vertical element
Kristin Kerst
Rep Power: 15 |
I tried to create a channel with a vertical element in it. I "build" it with blockMesh. Without the element in the channel, I get good results. But with the element, I get unbelievable high velocity. I changed the geometry several times, but it doesn't became better. (And checkMesh gives me OK.) If somebody has some experience with the same probleme, it would be great. My blockMeshDic: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (-0.1365 0 0) (0 0 0) (0.013 0 0) (0.5135 0 0) (-0.1365 0 0.0455) (0.0455 0 0.0455) (0.0585 0 0.0455) (0.5135 0 0.0455) (-0.1365 0 0.091) (0 0 0.091) (0.013 0 0.091) (0.5135 0 0.091) (-0.1365 0.039 0) (0 0.039 0) (0.013 0.039 0) (0.5135 0.039 0) (-0.1365 0.039 0.0455) (0.0455 0.039 0.0455) (0.0585 0.039 0.0455) (0.5135 0.039 0.0455) (-0.1365 0.039 0.091) (0 0.039 0.091) (0.013 0.039 0.091) (0.5135 0.039 0.091) (-0.1365 0.052 0) (0 0.052 0) (0.013 0.052 0) (0.5135 0.052 0) (-0.1365 0.052 0.0455) (0.0455 0.052 0.0455) (0.0585 0.052 0.0455) (0.5135 0.052 0.0455) (-0.1365 0.052 0.091) (0 0.052 0.091) (0.013 0.052 0.091) (0.5135 0.052 0.091) (-0.1365 0.091 0) (0 0.091 0) (0.013 0.091 0) (0.5135 0.091 0) (-0.1365 0.091 0.0455) (0.0455 0.091 0.0455) (0.0585 0.091 0.0455) (0.5135 0.091 0.0455) (-0.1365 0.091 0.091) (0 0.091 0.091) (0.013 0.091 0.091) (0.5135 0.091 0.091) ); edges ( ); blocks ( hex (0 1 13 12 4 5 17 16) (30 10 11) simpleGrading (0.5 1 1) hex (1 2 14 13 5 6 18 17) (4 10 11) simpleGrading (1 1 1) hex (2 3 15 14 6 7 19 18) (80 10 11) simpleGrading (3 1 1) hex (12 13 25 24 16 17 29 28) (30 4 11) simpleGrading (0.5 1 1) hex (14 15 27 26 18 19 31 30) (80 4 11) simpleGrading (3 1 1) hex (24 25 37 36 28 29 41 40) (30 10 11) simpleGrading (0.5 1 1) hex (25 26 38 37 29 30 42 41) (4 10 11) simpleGrading (1 1 1) hex (26 27 39 38 30 31 43 42) (80 10 11) simpleGrading (3 1 1) hex (4 5 17 16 8 9 21 20) (30 10 11) simpleGrading (0.5 1 1) hex (5 6 18 17 9 10 22 21) (4 10 11) simpleGrading (1 1 1) hex (6 7 19 18 10 11 23 22) (80 10 11) simpleGrading (3 1 1) hex (16 17 29 28 20 21 33 32) (30 4 11) simpleGrading (0.5 1 1) hex (18 19 31 30 22 23 35 34) (80 4 11) simpleGrading (3 1 1) hex (28 29 41 40 32 33 45 44) (30 10 11) simpleGrading (0.5 1 1) hex (29 30 42 41 33 34 46 45) (4 10 11) simpleGrading (1 1 1) hex (30 31 43 42 34 35 47 46) (80 10 11) simpleGrading (3 1 1) ); patches // keyword ( patch // patch type for patch 0 inlet // patch name ( (0 12 16 4) (12 24 28 16) (24 36 40 28) (4 16 20 8) (16 28 32 20) (28 40 44 32) ) // end of 0th patch definition patch // patch type for patch 1 outlet // arbitrary patch name ( (3 15 19 7) (15 27 31 19) (27 39 43 31) (7 19 23 11) (19 31 35 23) (31 43 47 35) ) wall Wall ( (0 1 5 4) (1 2 6 5) (2 3 7 6) (4 5 9 8) (5 6 10 9) (6 7 11 10) (8 9 21 20) (9 10 22 21) (10 11 23 22) (20 21 33 32) (22 23 35 34) (32 33 45 44) (33 34 46 45) (34 35 47 46) (36 37 41 40) (37 38 42 41) (38 39 43 42) (40 41 45 44) (41 42 46 45) (42 43 47 46) (0 1 13 12) (1 2 14 13) (2 3 15 14) (12 13 25 24) (14 15 27 26) (24 25 37 36) (25 26 38 37) (26 27 39 38) (13 14 18 17) (17 18 22 21) (14 26 30 18) (18 30 34 22) (25 26 30 29) (29 30 34 33) (13 25 29 17) (17 29 33 21) ) ); mergePatchPairs ( ); // ************************************************** *********************** // |
February 7, 2011, 16:59 |
Martin
Rep Power: 21 |
Hi Kristin,
your mesh works for me, see the attached case... Run with: blockMesh simpleFoam You should post your complete case, if you still have problems... Martin |
February 8, 2011, 05:20 |
Kristin Kerst
Rep Power: 15 |
Hello Martin,
thank you much for you answer. I actually also tried it with simpleFoam and the results are good. I should have mentioned: At first I tried it with icoFoam. So, I think the problem was the wrong solver. It might be another forum, but I try to build a static mixer. (In my mesh there is only the first element.) I'd like to get a concentration field (skalar field) of a tracer fluid, that comes in a little injector in the channel. Do you think, that it is possible? I thought about using scalarTranportFoam for the Problem, but I don't know, how to define the small "injector-inlet" Many greetings Kristin |
February 8, 2011, 06:03 |
#4 | |
Martin
Rep Power: 21 |
Hi Kristin,
icoFoam and nonNewtonianIcoFoam are running fine, too. You must set a rather small time step, so that the courant number stays low. Quote:
What kind of fluid do you want to handle? Water, or some nonnewtonian fluid? Is it turbulent flow or laminar? Is it compressible or incompressible? Does the scalar to be mixed in take influence on the flow (i.e. can it be handled as a passive scalar transport or not)? A simple approach would be: - use simpleFoam as a base - add a passive scalar transport as described here: http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam - add an additional patch to your mesh (p.e. in the middle of the inlet patch) which handles the scalar input (this patch has fixed inlet value of 1, rest of inlet patch has inlet value 0) Best regards Martin |
February 8, 2011, 08:17 |
Kristin Kerst
Rep Power: 15 |
Hello Martin,
you are right, I decreased the timestep once again and now it works. (For estimating the timestep, I used following: Co = (u* delta t)/delta x (Co ... <1) u = 0.1 m/s delta x = 0.0026 m ==> delta t = 0.0208 s (Don't know why it is not okay.)) What kind of fluid do you want to handle? Water, or some nonnewtonian fluid? water Is it turbulent flow or laminar? laminar, for the first Is it compressible or incompressible? incompressible Does the scalar to be mixed in take influence on the flow (i.e. can it be handled as a passive scalar transport or not)? it can be handled as a passive scalar A simple approach would be: - use simpleFoam as a base Okay. - add a passive scalar transport as described here: http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam The tutorial confuses me. How to define the passive scalar things? (Sorry, it's my first project with OpenFOAM.) - add an additional patch to your mesh (p.e. in the middle of the inlet patch) Yes, that's where the injection is located. Do I have to define this in the blockMeshDic? If yes, how? which handles the scalar input (this patch has fixed inlet value of 1, rest of inlet patch has inlet value 0) Whould be great, if this would work. Best regards Kristin |
February 8, 2011, 08:34 |
Kristin Kerst
Rep Power: 15 |
By the way, this is how the static mixer looks like:
I started with the simulation around a single element. Thank you for your help. |
February 8, 2011, 09:27 |
#7 | |
Martin
Rep Power: 21 |
Your static mixer will look great, especially if you make your whole mesh with blockMesh
Actually, I thought about doing exactly this to improve mixture of clay like ceramics for extrusion process. Concerning your estimation of the Co number: start a simulation with a much lower Co, let's say Co < 0.01. You can increase the timestep during runtime, as soon, as the simulation starts converging. Another fine solution is to use the automatic determined Courant number as it is done in interFoam. Have a look there, you only have to copy a few lines of code to make icoFoam use it, too. On the other hand, simpleFoam is the best choice to get results fast (due to its steady state flow approach). And if you want to stay with blockMesh, you should consider creating the meshes in parameterized way. I use python to create my blockMeshDicts (simple example is here, see post #4: http://www.cfd-online.com/Forums/ope...arge-mesh.html). If you search the forum you will find the m4 tool, which is used quite commonly to automize blockMeshDict creation. Another useful hint for blockMesh: you can add a name for each block, so you can handle the mesh very conveniently in paraFoam. Just define the blocks this way: Code:
hex (0 1 13 12 4 5 17 16) name_for_this_block (30 10 11) simpleGrading (0.5 1 1) When dealing with additional segments of your static mixer, have a look at the mergePatchPairs functionality. You can stick the segments together without having the topology going through the whole geometry. To start with your simpleFoam improvement: copy the simpleFoam solver to your $(FOAM_USER_APPBIN) folder, so that you don't mess up with the original source codes. It's described in the "confusing" tutorial in step 2. Instead of using a field "T", name it the way you prefer ("coloredWater" for example). Following the tutorial should give you the solution you are looking for. Quote:
But before I take all the fun of exploring and programming OpenFOAM away from you, I should stop here Have fun Martin |
February 8, 2011, 11:14 |
Kristin Kerst
Rep Power: 15 |
Hello Martin,
thank you for your tipps with blockMesh. Yes, I want to try it with blockMesh. Improving simpleFoam seems to be not easy for me. I am not very familiar with programming, but I'll try. Hope, it will work. And one last question, do you think, that scalarTransportFoam could help? Many greetings |
February 8, 2011, 11:37 |
#9 |
Martin
Rep Power: 21 |
Hi Kristin,
after running simpleFoam you will have an U file for the converged simulation. With this U you can start scalarTransportFoam as a follow up simulation. However it might run faster (and may be more convenient) if you include the scalar transport into the steady state solver simpleFoam, since scalarTransportFoam is a time discretized solver. But you are free to choose... Martin |
February 8, 2011, 11:44 |
#10 |
Kristin Kerst
Rep Power: 15 |
Thank you so much and wish you a good evening.
February 8, 2011, 13:45 |
#11 |
Kristin Kerst
Rep Power: 15 |
Hello Martin,
I tried scalarTransportFoam and it seems to work. I defined one inlet separately (28 40 32 20) in my old blockMeshDic. Now I am hanging with the "MergePairs-function". I searched in the forum and read http://www.openfoam.com/docs/user/blockMesh.php, but I don't know, how to split the patch. If you could help me once more, it would be great. My blockMeshDic: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (-0.1365 0 0) (0 0 0) (0.013 0 0) (0.5135 0 0) (-0.1365 0 0.0455) (0.0455 0 0.0455) (0.0585 0 0.0455) (0.5135 0 0.0455) (-0.1365 0 0.091) (0 0 0.091) (0.013 0 0.091) (0.5135 0 0.091) (-0.1365 0.039 0) (0 0.039 0) (0.013 0.039 0) (0.5135 0.039 0) (-0.1365 0.039 0.0455) (0.0455 0.039 0.0455) (0.0585 0.039 0.0455) (0.5135 0.039 0.0455) (-0.1365 0.039 0.091) (0 0.039 0.091) (0.013 0.039 0.091) (0.5135 0.039 0.091) (-0.1365 0.052 0) (0 0.052 0) (0.013 0.052 0) (0.5135 0.052 0) (-0.1365 0.052 0.0455) (0.0455 0.052 0.0455) (0.0585 0.052 0.0455) (0.5135 0.052 0.0455) (-0.1365 0.052 0.091) (0 0.052 0.091) (0.013 0.052 0.091) (0.5135 0.052 0.091) (-0.1365 0.091 0) (0 0.091 0) (0.013 0.091 0) (0.5135 0.091 0) (-0.1365 0.091 0.0455) (0.0455 0.091 0.0455) (0.0585 0.091 0.0455) (0.5135 0.091 0.0455) (-0.1365 0.091 0.091) (0 0.091 0.091) (0.013 0.091 0.091) (0.5135 0.091 0.091) (-0.1365 0.039 0.06825) //additional point 1 (-0.1365 0.052 0.06825) //additional point 2 ); edges ( ); blocks ( hex (0 1 13 12 4 5 17 16) (30 10 11) simpleGrading (0.5 1 1) hex (1 2 14 13 5 6 18 17) (4 10 11) simpleGrading (1 1 1) hex (2 3 15 14 6 7 19 18) (80 10 11) simpleGrading (3 1 1) hex (12 13 25 24 16 17 29 28) (30 4 11) simpleGrading (0.5 1 1) hex (14 15 27 26 18 19 31 30) (80 4 11) simpleGrading (3 1 1) hex (24 25 37 36 28 29 41 40) (30 10 11) simpleGrading (0.5 1 1) hex (25 26 38 37 29 30 42 41) (4 10 11) simpleGrading (1 1 1) hex (26 27 39 38 30 31 43 42) (80 10 11) simpleGrading (3 1 1) hex (4 5 17 16 8 9 21 20) (30 10 11) simpleGrading (0.5 1 1) hex (5 6 18 17 9 10 22 21) (4 10 11) simpleGrading (1 1 1) hex (6 7 19 18 10 11 23 22) (80 10 11) simpleGrading (3 1 1) hex (16 17 29 28 20 21 33 32) (30 4 11) simpleGrading (0.5 1 1) hex (18 19 31 30 22 23 35 34) (80 4 11) simpleGrading (3 1 1) hex (28 29 41 40 32 33 45 44) (30 10 11) simpleGrading (0.5 1 1) hex (29 30 42 41 33 34 46 45) (4 10 11) simpleGrading (1 1 1) hex (30 31 43 42 34 35 47 46) (80 10 11) simpleGrading (3 1 1) ); patches // keyword ( patch // patch type for patch 0 inlet1 // patch name ( (0 12 16 4) (12 24 28 16) (24 36 40 28) (4 16 20 8) (16 28 32 20) (28 40 49 48) ) // end of 0th patch definition patch // patch type for patch 0 inlet2 // patch name ( (28 40 49 48) ) // end of 1th patch definition patch // patch type for patch 1 outlet // arbitrary patch name ( (3 15 19 7) (15 27 31 19) (27 39 43 31) (7 19 23 11) (19 31 35 23) (31 43 47 35) ) wall Wall ( (0 1 5 4) (1 2 6 5) (2 3 7 6) (4 5 9 8) (5 6 10 9) (6 7 11 10) (8 9 21 20) (9 10 22 21) (10 11 23 22) (20 21 33 32) (22 23 35 34) (32 33 45 44) (33 34 46 45) (34 35 47 46) (36 37 41 40) (37 38 42 41) (38 39 43 42) (40 41 45 44) (41 42 46 45) (42 43 47 46) (0 1 13 12) (1 2 14 13) (2 3 15 14) (12 13 25 24) (14 15 27 26) (24 25 37 36) (25 26 38 37) (26 27 39 38) (13 14 18 17) (17 18 22 21) (14 26 30 18) (18 30 34 22) (25 26 30 29) (29 30 34 33) (13 25 29 17) (17 29 33 21) ) ); mergePatchPairs ( (inlet1 inlet2) // merge patch pair 0 ); // ************************************************** *********************** // |
February 8, 2011, 14:39 |
#12 |
Martin
Rep Power: 21 |
Hi Kristin,
first, here is a simple example how to use the mergePatchPairs stuff: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (-0.1365 0 0) (0 0 0) (0.013 0 0) (0.5135 0 0) (-0.1365 0 0.0455) (0.0455 0 0.0455) (0.0585 0 0.0455) (0.5135 0 0.0455) (-0.1365 0 0.091) (0 0 0.091) (0.013 0 0.091) (0.5135 0 0.091) (-0.1365 0.039 0) // 12 (0 0.039 0) (0.013 0.039 0) (0.5135 0.039 0) (-0.1365 0.039 0.0455) (0.0455 0.039 0.0455) (0.0585 0.039 0.0455) (0.5135 0.039 0.0455) (-0.1365 0.039 0.091) // 20 (0 0.039 0.091) (0.013 0.039 0.091) (0.5135 0.039 0.091) (-0.1365 0.052 0) (0 0.052 0) (0.013 0.052 0) (0.5135 0.052 0) (-0.1365 0.052 0.0455) (0.0455 0.052 0.0455) (0.0585 0.052 0.0455) // 30 (0.5135 0.052 0.0455) (-0.1365 0.052 0.091) (0 0.052 0.091) (0.013 0.052 0.091) (0.5135 0.052 0.091) (-0.1365 0.091 0) (0 0.091 0) (0.013 0.091 0) (0.5135 0.091 0) (-0.1365 0.091 0.0455) // 40 (0.0455 0.091 0.0455) (0.0585 0.091 0.0455) (0.5135 0.091 0.0455) (-0.1365 0.091 0.091) (0 0.091 0.091) (0.013 0.091 0.091) (0.5135 0.091 0.091) // 47 (-0.1365 0.039 0.06825) //additional point 1 (-0.1365 0.052 0.06825) //additional point 2 (-0.2 0 0) // 50 martins points (-0.2 0.091 0) (-0.2 0.091 0.091) (-0.2 0 0.091) (-0.1365 0 0) // 54 martins points (-0.1365 0.091 0) (-0.1365 0.091 0.091) (-0.1365 0 0.091) ); edges ( ); blocks ( hex (0 1 13 12 4 5 17 16) (30 10 11) simpleGrading (0.5 1 1) hex (1 2 14 13 5 6 18 17) (4 10 11) simpleGrading (1 1 1) hex (2 3 15 14 6 7 19 18) (80 10 11) simpleGrading (3 1 1) hex (12 13 25 24 16 17 29 28) (30 4 11) simpleGrading (0.5 1 1) hex (14 15 27 26 18 19 31 30) (80 4 11) simpleGrading (3 1 1) hex (24 25 37 36 28 29 41 40) (30 10 11) simpleGrading (0.5 1 1) hex (25 26 38 37 29 30 42 41) (4 10 11) simpleGrading (1 1 1) hex (26 27 39 38 30 31 43 42) (80 10 11) simpleGrading (3 1 1) hex (4 5 17 16 8 9 21 20) (30 10 11) simpleGrading (0.5 1 1) hex (5 6 18 17 9 10 22 21) (4 10 11) simpleGrading (1 1 1) hex (6 7 19 18 10 11 23 22) (80 10 11) simpleGrading (3 1 1) hex (16 17 29 28 20 21 33 32) (30 4 11) simpleGrading (0.5 1 1) hex (18 19 31 30 22 23 35 34) (80 4 11) simpleGrading (3 1 1) hex (28 29 41 40 32 33 45 44) (30 10 11) simpleGrading (0.5 1 1) hex (29 30 42 41 33 34 46 45) (4 10 11) simpleGrading (1 1 1) hex (30 31 43 42 34 35 47 46) (80 10 11) simpleGrading (3 1 1) hex (50 51 52 53 54 55 56 57) martins_extrablock (40 20 20) simpleGrading (1 1 1) ); patches // keyword ( patch // patch type for patch 0 inlet1 // patch name ( (0 12 16 4) (12 24 28 16) (24 36 40 28) (4 16 20 8) (16 28 32 20) (28 40 44 32) ) // end of 0th patch definition patch // patch type for patch 0 inlet2 // patch name ( //(28 40 44 32) ) // end of 1th patch definition patch // patch type for patch 1 outlet // arbitrary patch name ( (3 15 19 7) (15 27 31 19) (27 39 43 31) (7 19 23 11) (19 31 35 23) (31 43 47 35) ) wall Wall ( (0 1 5 4) (1 2 6 5) (2 3 7 6) (4 5 9 8) (5 6 10 9) (6 7 11 10) (8 9 21 20) (9 10 22 21) (10 11 23 22) (20 21 33 32) (22 23 35 34) (32 33 45 44) (33 34 46 45) (34 35 47 46) (36 37 41 40) (37 38 42 41) (38 39 43 42) (40 41 45 44) (41 42 46 45) (42 43 47 46) (0 1 13 12) (1 2 14 13) (2 3 15 14) (12 13 25 24) (14 15 27 26) (24 25 37 36) (25 26 38 37) (26 27 39 38) (13 14 18 17) (17 18 22 21) (14 26 30 18) (18 30 34 22) (25 26 30 29) (29 30 34 33) (13 25 29 17) (17 29 33 21) ) patch martins_new_inlet ( (50 51 52 53) ) patch master ( (54 55 56 57) ) wall extraWall ( (50 54 57 53) (53 57 56 52) (51 55 56 52) (50 54 55 51) ) ); mergePatchPairs ( (master inlet1) // merge patch pair 0 ); // ************************************************** *********************** // So you can create a cute inlet for your passive scalar, and you don't have to think much about how to combine the inlet block and the rest of your mesh. Just merge them... By the way: if you don't use it already, try the pyFoamDisplayBlockMesh tool from the pyFoam utility to visualize the blockMeshDict definitions. I'll build up another example based on your proposed solution... Martin |
February 8, 2011, 14:53 |
#13 |
Martin
Rep Power: 21 |
And here is the case:
Have a careful look to the files in 0/*: The file "T" is prepared for the passive scalar. The files "U" and "p" got entries for inlet1 and inlet2. In this case it's not necessary to use mergePatchPairs! So, let simpleFoam run on this case, and run scalarTransportFoam with the settings from "T" afterwards. Have fun Martin |
February 8, 2011, 15:03 |
#14 |
Kristin Kerst
Rep Power: 15 |
Hi Martin,
thank you. Actually, I use a ".foam"-file to see the mesh in paraview, but I'll try "pyFoamDisplayBlockMesh tool". I had the idea to make a mesh like in the sketch: Okay, actually I try your case ... |
February 8, 2011, 15:30 |
#15 |
Kristin Kerst
Rep Power: 15 |
Hi Martin,
first the mesh: I get following error: PHP Code:
February 8, 2011, 15:42 |
#16 |
Martin
Rep Power: 21 |
You are using OpenFOAM 1.5 on a Mac, right? Can you upgrade to OpenFOAM 1.6.x or higher? Or do you have a linux machine available?
Martin |
February 8, 2011, 15:54 |
#17 |
Kristin Kerst
Rep Power: 15 |
Then the case:
blockMesh was okay. Then I had an error: "keyword is undefined in dictionary "/Users/hilmarkerst/OpenFOAM/hilmarkerst-1.5/run/tutorials/simpleFoam/channel_with_element2/constant/RASProperties"," and so I wrote "laminarCoeffs { }", like in "pitzDaily" Same for the "wallFunctionCoeffs". And now I get following error: PHP Code:
But simpleFoam/scalarTransportFoam shouldn't be a problem. It works for me with the blockMeshDic you used and the directories I copied from pitzDaily. |
July 11, 2012, 14:47 |
#18 |
HD
Rep Power: 14 |
Hi Martin,
I am learning OF currently, so I downloaded the file channel_with_element.tar.gz as exercise. I could run it, but the generated pressure field showed some negative values, which shouldn't be the case. I followed the steps in your post, and I am not sure where I did wrong. If you have any idea what the problems might be, I really appreciate it. Thank you. Best, Hang |
July 11, 2012, 15:13 |
#19 |
Martin
Rep Power: 21 |
Hi Hang,
the pressure in simpleFoam is the relative pressure only (because it's an incompressible solver). If you put a fixedValue of 100000 at the outlet patch you will not get negative pressure any more. Martin |
July 11, 2012, 16:05 |
#20 |
HD
Rep Power: 14 |
Hi Martin,
Thank you for your reply. Now I see~ Best, Hang |
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM | Ancioi | OpenFOAM Meshing & Mesh Conversion | 17 | January 8, 2019 23:50 |
Identifying Markers in a CGNS Mesh | tjim | SU2 | 3 | October 12, 2018 01:21 |
[Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 05:29 |
natural convection in vertical channel | Arjun123 | FLUENT | 11 | November 23, 2014 09:09 |
autoPatch error, mesh quality related...? | Alexvader | OpenFOAM | 0 | October 6, 2011 17:57 |
