[snappyHexMesh] Having troubles generating a simple mesh of a pump with basin |
August 28, 2014, 03:40 |
#1 | |
Mehdi GHOZALI
Rep Power: 12 |
Dear Bruno, I am sorry if there are other threads about this topic. I think I went throught all the discussions about this problem but could not find the answer and I am really confused. So what I would like to do is presented in the picture "geometry". to do that I created a blockMesh and SLT ASCII of all faces (inlet, outlet, pump ...etc) BUT when I use snappyHexMesh I put the locationInMesh inside the "bassin". The results is presented in pictures "wrong1 and wrong1_withPump". When I change the locationInMesh location and I put it inside the "pump" I get what is presented in picture named "wrong2". I know that there is a lot of threads explaining how to do using some "chtMultiRegionFoam", but I don't seem to understand how it is working. Can you please give me help here?! Thank you Regards, Dadou |
September 8, 2014, 05:04 |
#2 | |
Tobias Holzmann
Rep Power: 51 |
I think I will regenerate the chtMultiRegion tutorial again and upload it. (and also update the wiki snappyHexMesh side) I only need a few time @Dadou: I think for your case you do not have to use a multi region domain, aren't you? Regards Tobi
Keep foaming, Tobias Holzmann |
September 8, 2014, 06:30 |
#3 | |
Mehdi GHOZALI
Rep Power: 12 |
For now I have a blockMesh with the same height as the pump just to keep the pump and outlet. Because if I do a small blockMesh the snappyHexMesh will get rid of the rest of the pump (that is not inside the blockMesh) What should I do ?! Thanks Tobi Dadou |
September 8, 2014, 06:33 |
#4 | |
Tobias Holzmann
Rep Power: 51 |
you mix up something. Multi region meshing is for heat transfer (multi regions, like air, water, other fluids, solids) or meshes that are not connected at all (fluid domain is separated... e.g. two parallel pipes not connected but you have only one fluid and maybe you connect outlet_solid1 to the inlet_solid2 with some bc). You should only make one mesh. Can you publish your STL-files or your case so that I can check it out and give you a solution. Anyway, maybe I miss understand what you are wanna do
September 8, 2014, 08:06 |
#5 | |
Mehdi GHOZALI
Rep Power: 12 |
Well I think I miss understand what multi region was. Anyway you can find my stl and blockmesh attached You have to know that in my blockMesh there is two blocks but I only one the first of them, I added the second because i couldn't mesh the extra pump without it. Thank you |
September 8, 2014, 09:36 |
Tobias Holzmann
Rep Power: 51 |
@bruno,
maybe its possible to move the posts which are not corresponding to that thread into a other one... @dadou: in the attachment you find the file. Following steps to do Code:
blockMesh snappyHexMesh paraview --data=paraview //or paraFoam, or paraview and load the paraview.foam file
September 10, 2014, 03:11 |
#7 | |
Mehdi GHOZALI
Rep Power: 12 |
I am so thankful. Just one question how did you create regionSTL???!! I am trying to do my own Thank you again Dadou |
September 20, 2014, 09:40 |
#8 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
I suggest you try using Blender along with SwiftSnap:
Bruno |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[snappyHexMesh] problems generating clean mesh | Christian_tt | OpenFOAM Meshing & Mesh Conversion | 2 | June 20, 2019 05:39 |
Bad elements after generating unstructured volume mesh | max_beetle | Pointwise & Gridgen | 0 | October 24, 2017 01:52 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
