[snappyHexMesh] Meshing a sphere with snappyHexMesh (for beginners)
Like Tree1Likes
  • 1 Post By Tobi
Old   February 2, 2015, 07:34
Default Meshing a sphere with snappyHexMesh (for beginners)
Tobi's Avatar
Tobias Holzmann
Hello everybody,
due to the fact that I get messages frequently, I created a new very simple meshing tutorial. In this tutorial, the aim is to mesh a sphere inside a channel and add several layers (six layers 100%).
This is only for really beginners who want to start with snappyHexMesh.
You can find this tutorial here: https://holzmann-cfd.de/
Hope its helpful,
babakflame likes this.
Keep foaming,
Tobias Holzmann
Old   May 27, 2015, 10:27
Yaoyina
yaoyina is on a distinguished road
Hi,I've downloaded the case you share.As there is no blockMeshDict in the folder,I make a blockMeshDict by myself.I use blockMesh to get a big cube,and use snappyHexMesh to get the sphere.My question is how could I retain both the cube and the sphere.It means that I don't want to remove any cells in the whole region.Can you give me some advice?Thank you in advance!
yaoyina is offline   Reply With Quote
Old   May 29, 2015, 14:28
Derek Mitchell
derekm is on a distinguished road
I ran this under 2.4.0 and it fails to work. I enclose the log file
A CHEERING BAND OF FRIENDLY ELVES CARRY THE CONQUERING ADVENTURER OFF INTO THE SUNSET
derekm is offline   Reply With Quote
Old   May 29, 2015, 15:36
Tobi's Avatar
Tobias Holzmann
Hello yaoyina,
Therefore you have to use faceZones and CellZones in sHMDict. Check out the cht tutorials. Further more you create the mesh in my case with ideasUnvToFoam. Check the script.
@derekm as you saw on my webpage, the tutorial is made for 2.3.1.
At the moment I have not installed 2.4.0 because there is no reason to do this yet.
I will check it in 2 weeks.
Keep foaming,
Tobias Holzmann
Old   May 31, 2015, 17:29
Derek Mitchell
got it wrong it does work on 2.4.0 or at least the same as 2.3.1
Old   June 1, 2015, 01:52
Tobi's Avatar
Tobias Holzmann
Well done and good to know.
Keep foaming,
Tobias Holzmann
Old   November 20, 2016, 12:45
Arsalan
arsalan.dryi is on a distinguished road
Dear Tobias,
I want to mesh around a sphere in a cube and also inside the sphere while I'm using your tutorial for the first one. I'm using the searchableSphere option for defining sphere surface and blockMesh for the background mesh instead of using stl surfaces. (water-proof stl surfaces from salome were also tested.)
Everything goes well when the mesh is coarse and surfaceRefinement level is set to a low number around the sphere. But I need a finer mesh for the background and increasing grid numbers from blockMeshDict or using a high refinement level around the surface, results a bad mesh quality (high skewness) and no layers around the sphere. I attached test case for more information. Briefly, I need a finer background mesh with high number of layers around the sphere.
I would be very grateful if you could give me some comment for my problem.
Thanks in advance,
Regards,
Arsalan.
arsalan.dryi is offline   Reply With Quote
Old   November 20, 2016, 17:39
Tobi's Avatar
Tobias Holzmann
Dear arsalan,
I will not check your case because there is no time at the moment. Just one tip. Scale your geometry by 1000 mesh everything and downscale it again. if it will not work you do something wrong
Good luck
Keep foaming,
Tobias Holzmann
[snappyHexMesh] snappyHexMesh - 3D Wing Meshing Setup & Trials denbjornen OpenFOAM Meshing & Mesh Conversion 1 May 25, 2020 11:14
[snappyHexMesh] bumps and broken surface after meshing with snappyhexmesh Yemi2favours OpenFOAM Meshing & Mesh Conversion 0 February 12, 2018 12:07
[snappyHexMesh] Error "keyword meshQualityControls is undefined" while meshing with snappyHexMesh JeanDidier OpenFOAM Meshing & Mesh Conversion 2 February 9, 2018 14:48
[snappyHexMesh] Sphere in a channel by snappyHexMesh arsalan.dryi OpenFOAM Meshing & Mesh Conversion 0 November 14, 2016 16:01
[ANSYS Meshing] Structured Volumetric Meshing in Workbench for a Sphere AS_Aero ANSYS Meshing & Geometry 0 March 19, 2013 06:28
