[snappyHexMesh] Exclude regions for layer growth with snappyHexMesh |
November 9, 2017, 17:36 |
Hilbert
Rep Power: 10 |
Dear Foamers,
I am trying to learn myself snappyHexMesh and I am running to a problem that I hope somebody can help me with. The geometry that I am trying to mesh has a thin channel in it which needs to be meshed but does not need a boundary layer mesh. Up to the layer addition process the meshing goes without a hitch, but after the first layer addition iteration SHM crashes. Code:
mpirun noticed that process rank 37 with PID 48495 on node ec01b08 exited on signal 8 (Floating point exception). Is there a way that I can check if my hypothesis is correct? Is there a way I can exclude this small channel from the layer addition process? Any suggestions would be greatly appreciated. |
[snappyHexMesh] Creating STL files with regions for snappyHexMesh | nusivares | OpenFOAM Meshing & Mesh Conversion | 4 | August 7, 2018 20:09 |
Mesh refinement regions with snappyHexMesh | andrei.cimpoeru | OpenFOAM Pre-Processing | 4 | January 25, 2016 07:58 |
[snappyHexMesh] Using snappyHexMesh for multiple enclosed regions | richard_vega | OpenFOAM Meshing & Mesh Conversion | 0 | November 13, 2014 14:28 |
[snappyHexMesh] SnappyHexMesh and MultiRegion - get regions from Salome to OF | dzi | OpenFOAM Meshing & Mesh Conversion | 2 | September 4, 2014 10:04 |
[snappyHexMesh] does SnappyHexMesh allows intersection of refinement regions | douglasx | OpenFOAM Meshing & Mesh Conversion | 2 | April 2, 2014 09:30 |
