[snappyHexMesh] addLayer on sHM
Old   July 3, 2013, 10:22
Default addLayer on sHM
Mehdi GHOZALI
Dadou is on a distinguished road
I'm using snappyHexMesh, and I don't understand the part that adds layers. I can't figure out waht "minThickness" does. I've been working on it all day, I understood that it's the thickness of the minimum layer below which height layers will automatically be collapsed. but I don't really see a difference.
Can someone, please explain (better than what's on the paper) how it works ?
Thank you
Dadou
Dadou is offline   Reply With Quote
Old   July 4, 2013, 12:13
Markus Rehm
markusrehm is on a distinguished road
have you studied that (slide 41)?
http://www.openfoamworkshop.org/2012...ningSlides.tgz
Markus
markusrehm is offline   Reply With Quote
Old   July 5, 2013, 03:36
Mehdi GHOZALI
Hi Markus,
Yes I've studied that the whole week, I understood some but my problem is the minimumThickness I don't know what it changes, I've tried a lot of cases but don't understand
But thank you anyway
Originally Posted by markusrehm View Post
Markus
Old   July 5, 2013, 09:08
Markus Rehm
the value of "minThickness" is a threshold value. If the thickness drops below this value the layer is collapsed, it means no layer will be created.
Markus
Old   July 8, 2013, 03:20
Mehdi GHOZALI
Thank you Markus.
And it's the same if I have many Layers ?
Dadou
Old   July 8, 2013, 07:00
Mehdi GHOZALI
what about ΔL? when snappyHexMesh calculates it ?
Thanks for your help
Dadou
Originally Posted by Dadou View Post
Thank you Markus.
Dadou
[snappyHexMesh] Problem with sHM addLayer Jinjolee OpenFOAM Meshing & Mesh Conversion 8 April 18, 2019 13:55
[snappyHexMesh] different sHM results on same geometry when everythin is in one or several stl-files. Laika OpenFOAM Meshing & Mesh Conversion 1 September 8, 2016 04:09
[snappyHexMesh] 2D AMI Moving Mesh with sHM; How hard can this be? ADGlassby OpenFOAM Meshing & Mesh Conversion 18 June 18, 2013 06:07
[snappyHexMesh] SHM: feature edge snapping not conforming thab OpenFOAM Meshing & Mesh Conversion 3 November 26, 2012 14:04
[snappyHexMesh] sHM with cyclic patch on stl geometry johannesk OpenFOAM Meshing & Mesh Conversion 2 August 21, 2009 09:08
