[Technical] Using stitchmesh on imported gmsh meshes
Old   November 26, 2005, 04:22
Default Using stitchmesh on imported gmsh meshes
Christian Hubbauer
christian67 is on a distinguished road
Dear all,
can anybody help me on how the stitchmesh utility works ?
I've tried to create a hex gmsh mesh in order to understand. The mesh has been imported with gmshToFoam and the patches created look quite reasonable in paraFoam.
Executing "stitchmesh . stitchtest patch4 patch3
-partial" leads to an error message
"--> FOAM FATAL ERROR : Face 3683 reduced to less than 3 points. Topological/cutting error B.
Old face: 1(10) new face: 1(10)
I'll try to attach the case here.
Any help is appreciated.
Christian
stitchtest.tar.gz
christian67 is offline   Reply With Quote
[mesh manipulation] stitchMesh: multiple meshes GerhardHolzinger OpenFOAM Meshing & Mesh Conversion 3 August 25, 2017 12:43
[OpenFOAM] Visualizing imported meshes sudo ParaView 1 November 9, 2013 15:23
[mesh manipulation] Problem with stitchMesh: it does not work in meshes with several common patches arnau1985 OpenFOAM Meshing & Mesh Conversion 2 June 25, 2013 08:49
using METIS functions in fortran dokeun Main CFD Forum 7 January 29, 2013 04:06
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
