[snappyHexMesh] universal decomposeParDict
Old   March 31, 2017, 08:36
Default universal decomposeParDict
Manuel Fermin Fonseca
manuelffonseca is on a distinguished road
Hi i need a decomposeParDict that work for a single precessor, my snappyHexmesh ask me for this file. My OpenFoam is the 2.1 version
Create time
Create mesh for time = 0
Read mesh in = 0.328 s
--> FOAM FATAL IO ERROR:
cannot open file
file: D:/Mis documentos/CFD/Pruebas CFD/Generati
ng-Mesh-using-snappyHexMesh-Codefiles/flange_1/system/decomposeParDict at line 0
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 87.
FOAM exiting
i have tried with another decomposeParDict in the tutorial folder, and i obtained this and the snappyHexmesh doesnt work.
Please Help me
Create time
Overall mesh bounding box : (-0.03 -0.03 -0.03) (0.03 0.03 0.01)
Relative tolerance : 1e-006
Absolute matching distance : 9.38083e-008
Reading refinement surfaces.
Read refinement surfaces in = 0.11 s
Reading refinement shells.
Refinement level 3 for all cells inside refineHole
Read refinement shells in = 0 s
Setting refinement level of surface to be consistent with shells.
Checked shell refinement in = 0.078 s
Reading features.
Refinement level 0 for all cells crossed by feature "flange.eMesh" (767 points,
776 edges).
Detected 18 featurePoints out of 767 on feature flange.eMesh
Read features in = 0.015 s
Determining initial surface intersections
Edge intersection testing:
Number of edges : 25200
Number of edges to retest : 25200
Number of intersected edges : 1507
Calculated surface intersections in = 0.172 s
Initial mesh : cells:8000 faces:25200 points:9261
Cells per refinement level:
0 8000
Adding patches for surface regions
Patch Type Region
flange:
4 wall flange_patch1
5 wall flange_patch2
6 wall flange_patch3
7 wall flange_patch4
Added patches in = 0.016 s
Selecting decompositionMethod simple
Refinement phase
Found point (-9.23149e-005 -0.0025 -0.0025) in cell 5389 on processor 0
Feature refinement iteration 0
manuelffonseca is offline   Reply With Quote
DecomposeParDict with weightField mortezahdr OpenFOAM 1 February 3, 2022 10:10
decomposeParDict foamiste OpenFOAM Running, Solving & CFD 4 June 30, 2016 07:07
Environment variable ($MPI_PROCS) in decomposeParDict Pj. OpenFOAM Running, Solving & CFD 2 April 8, 2013 02:38
Universal file moiami FLUENT 0 November 25, 2002 03:20
Why Turbulence models are not universal. Senthil Main CFD Forum 4 July 5, 2000 04:34
