[mesh manipulation] refineMesh: command not found |
August 5, 2017, 12:15 |
Bartlomiej
Hi
I have got a problem. When I want to use commad: refineMesh, it appear: "refineMesh: command not found". Could anybody help me? |
August 6, 2017, 10:29 |
Bartlomiej
I found solution. I had to compile files again. If someone wants to know how to do it - here is answer:
https://www.cfd-online.com/Forums/op...not-found.html I close the topic |
command, not found, refine mesh |
[Gmsh] Insatlling gmsh from the source code-issue? | CFD-Lover | OpenFOAM Meshing & Mesh Conversion | 20 | June 12, 2018 06:39 |
Gmsh installation on terminal help | spitfire | Main CFD Forum | 4 | July 27, 2017 15:11 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
Problems Installing OF 1.6 32 bit | bucksfan | OpenFOAM Installation | 19 | August 4, 2009 01:36 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
