[mesh manipulation] Openfoam mesh file format |
September 18, 2017, 13:54 |
Nikhil
Rep Power: 10 |
Hello guys,
Does anyone know a link or reference to a document which explains how elements and their connectivity is stored in openfoam mesh file. Currently our solver supports .cgns files. we are looking forward to read and write openfoam meshes. Thanks!! |
October 4, 2017, 14:05 |
Thomas Evans
Rep Power: 10 |
OpenFOAM is designed to obscure the fact that this starts out fairly simple. Also, the documentation is very much piecemeal, but chapter 5 of the user guide is a good place to start.
Run a tutorial (any tutorial) then look under constant/polyMesh. There will be at least five files:
As long as these are in ASCII format, they are mostly self-explanatory. 'points' simply lists vertices in 3d. 'faces' lists faces generated by tracing a given set of vertices in order. 'owner' and 'neighbour' list the owner and non-owner cells which are connected by the given face. Faces without neighbour cells are exterior faces, and must be part of a boundary (see the 'boundary' file). You can denote a lack of neighbour either with a -1 or by simply truncating the neighbour file. This is why the neighbour file is often much shorter than the owner file. Also, for a given face the index of owner must be less than the index of neighbour. Plus, the face vector must point out of the owner cell. For boundary, know that the order of the faces must be: interior faces (no entry in boundary file) first patch second patch ... last patch ***************** Also, see https://www.cfd-online.com/Forums/op...mpactlist.html for faceCompactList and how to adjust for it. ****************** Some meshes included Zones and crap that I never use, good luck with those. |
December 3, 2017, 09:24 |
just my 2 cent take a look at https://openfoamwiki.net/index.php/S...GNS_Converters there i a commercial tool as well https://www.cfd-online.com/Forums/op...converter.html |
[Other] Tabulated thermophysicalProperties library | chriss85 | OpenFOAM Community Contributions | 62 | October 2, 2022 03:50 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
