[Gmsh] GmshToFoam undefined faces
Old   May 8, 2006, 02:05
Default GmshToFoam undefined faces
Giuseppe Noviello
derath is on a distinguished road
Hi to all
my name is Giuseppe and I'm new user of OF and gmsh.
I've a problem with my simple case a cube, so when I use gmshToFoam utility it report this warning:
Exec : gmshToFoam
/home/giuseppe/OpenFOAM/giuseppe-1.3/run/tutorials/simpleFoam prova cubef.msh
Date : May 08 2006
Time : 08:00:30
Host : linux
PID : 7819
Root : /home/giuseppe/OpenFOAM/giuseppe-1.3/run/tutorials/simpleFoam
Case : prova
Nprocs : 1
Create time
Read nVerts:865
Read nElems:4928
Mapping region 6 to Foam patch 0
Mapping region 15 to Foam patch 1
Mapping region 19 to Foam patch 2
Mapping region 23 to Foam patch 3
Mapping region 27 to Foam patch 4
Mapping region 28 to Foam patch 5
Mapping region 1 to Foam cellZone 0
Cells:
total:4016
hex :0
prism:0
pyr :0
tet :4016
Patches:
Patch Size
0 228
1 94
2 94
3 94
4 86
5 228
CellZones:
Zone Size
0 4016
--> FOAM Warning :
From function polyMesh::polyMesh(... construct from shapes...)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 573
Found 824 undefined faces in mesh; adding to default patch.
Finding faces of patch 0
Finding faces of patch 1
Finding faces of patch 2
Finding faces of patch 3
Finding faces of patch 4
Finding faces of patch 5
FaceZones:
Zone Size
Writing zone 0 to cellZone cellZone_0 and cellSet
End
where is my error?
someone can help me?
Thanks to all.
Giuseppe
derath is offline   Reply With Quote
Old   May 15, 2006, 04:39
Default It means you do not have defin
Mattijs Janssens
mattijs is on a distinguished road
It means you do not have defined gmsh surfaces on all boundary faces. You obviously have some:
Patch Size
0 228
1 94
2 94
3 94
4 86
5 228
but there are still 824 boundary faces that are not covered by gmsh surfaces.
mattijs is offline   Reply With Quote
Old   May 19, 2006, 06:35
Default Hi Mattijs exactly which is t
Giuseppe Noviello
Hi Mattijs
exactly which is the right procedure?
This is my simple geo file:
Point(1) = {0,0,0,0.1};
Point(2) = {0.5,0,0,0.1};
Point(3) = {0.0,0.5,0,0.1};
Point(4) = {0.5,0.5,0,0.1};
Line(1) = {1,2};
Line(2) = {2,4};
Line(3) = {4,3};
Line(4) = {3,1};
Line Loop(5) = {2,3,4,1};
Plane Surface(6) = {5};
Extrude {0,0,0.5} {
Surface{6};
Physical Surface(101) = {15,6,23,28,19,27};
Physical Volume(100)= {1};
I've seen that 824 faces is the number of prism which gmsh produce, beside tetrahedra is right?
Thanks in advantage
Giuseppe
Old   May 19, 2006, 12:58
Default Sorry not prism but triangles.
Giuseppe Noviello
Sorry not prism but triangles....
Old   May 19, 2006, 13:38
Default Hi, maybe its a bug and can be
newbee
Hi, maybe its a bug and can be solved by running the newest gmsh version (v1.65) at: http://geuz.org/gmsh/src/
If you are to use the mesh you might want to use the extra recombine posibillity in the extruded direction. see the totorial 3 for this.
Old   May 20, 2006, 07:53
Default Hi, Giuseppe, I ran your si
Pei-Ying Hsieh
hsieh is on a distinguished road
Hi, Giuseppe,
I ran your simple geo file. I got 336 triangles and the rests are Tets. I used gmsh 1.65. Your geo file looked fine to me.
Recombine Surface will give you hex and/or prism elements, which are better than tet elements.
Pei
hsieh is offline   Reply With Quote
Old   May 21, 2006, 01:47
Default Hi,Pei I've put Recombine Sur
Giuseppe Noviello
Hi,Pei
I've put Recombine Surface im my geo file but i've 96 Triangles 120 Quads 0 Tet 0 Hex and 0 prism
Extrude {0,0,0.5} {
Surface{6};
Recombine Surface{15,6,23,28,19,27};
moreover when I use gmshToFoam for import mesh I've FOAM FATAL ERROR : faces deallocated
Where is my mistake?
Thanks Giuseppe
Old   May 22, 2006, 04:54
Default I don't know much about gmsh b
Mattijs Janssens
I don't know much about gmsh but an error like
probably means that there are no volume elements (tets, hexes etc.) in the file you are trying to read. Just look at the file with an editor. 2nd number is the element type acc. to the gmsh documentation.
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) AndreP STAR-CCM+ 10 August 2, 2018 07:48
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
