[snappyHexMesh] Strange bumb on the surface
Old   November 3, 2011, 10:56
Default Strange bumb on the surface
vittorio.bissaro is on a distinguished road
Some problem when using snappy with boundary layer.
Strange bumbs appears on the surface of the geometry.
(look at the pictures)
Is it a common problem or I just need to choose the right parameters?
(I can add more information if needed)
Thanks a lot
vittorio.bissaro is offline   Reply With Quote
Old   November 3, 2011, 13:48
Retired Super Moderator
Bruno Santos
Greetings vittorio.bissaro and welcome to the forum!
That looks a bit like the bug reported here: http://www.openfoam.com/mantisbt/view.php?id=309 - but the bug reported there implies that the problem is related to large surfaces without additional feature edges on them.
Can you attach on your next post the "snappyHexMeshDict" file? Also, open the "*.obj" files in ParaView so you can verify what feature edges are being followed.
Any chance you can simplify the geometry to try and isolate the issue? If you can, you can then later use it for reporting it on the bug tracker in the link above.
Best regards,
Bruno
bumb, layer, mesh, snappy
Strange Behaviour of Free Surface talatgokcer OpenFOAM Running, Solving & CFD 1 March 13, 2016 09:02
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[snappyHexMesh] Add additional boundary layers to complex stl surface tobijingles OpenFOAM Meshing & Mesh Conversion 1 October 26, 2011 10:45
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
