[snappyHexMesh] defining boundary condition in SHM |
April 24, 2012, 10:02 |
Mihai Pruna
I tried this, but, after meshing, looking in the boundary file it generated, all the STL patches are walls!
SHM: sduct.stl { type triSurfaceMesh; name sduct; regions { Sductface1 { name Sductface1; type wall; } Sductface2 { name Sductface2; type wall; } SDuctInlet { name SDuctInlet; type patch; } SDuctOutlet { name SDuctOutlet; type patch; } } } Boundaries: Sductface1 { type wall; nFaces 139535; startFace 2352772; } Sductface2 { type wall; nFaces 13938; startFace 2492307; } SDuctInlet { type wall; nFaces 13938; startFace 2506245; } SDuctOutlet { type wall; nFaces 136863; startFace 2520183; } )
Mihai Pruna's Bio |
April 24, 2012, 12:06 |
Mihai Pruna
assuming my time 0 BCs are defined properly, does this even matter for simpleFoam to define the inlet as an inlet and the outlet as an outrlet,etc?
Mihai Pruna's Bio |
April 25, 2012, 04:39 |
cfdkid
Yes it does.
But you can overcome this "wall" by editing 0/u p adn all ... for -type "wall" to the one you want them to be like patch,empty,fixedValue; etc. Also you will be required to edit /constant/polyMesh/ boundary file for same i.e for stl walls where ever you need different type , name it accordingly. Remember few will still be type wall. Also point to be noted here is , this editing has to be done after meshing. Note: It is just nature of problem one is solving. In your case some internal flow might be taking place . Generally for outer flow less or no editing is required. ( only my guess)
________________________________________ Regards, CFDkid It never gets easier You just get Better |
April 25, 2012, 13:33 |
Mihai Pruna
hmm so far from the tests I did it seems inlets and outlets are overridden by setting the BCs.
Mihai Pruna's Bio |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
External Radiation Boundary Condition for Grid Interface | CFD XUE | FLUENT | 0 | July 9, 2010 02:53 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 06:49 |
