[blockMesh] How to use blockMesh to generate cylindrical T-junction
Old   July 12, 2012, 21:45
Smile How to use blockMesh to generate cylindrical T-junction
Bin Xu
norkistar is on a distinguished road
Hi Forums, I am new to OpenFOAM. I am struggling to use blockMesh to generate cylindrical T-junction geometry. Can anyone give clue or can post a simple blockMeshDict file that is two cylinder with same diameter then intersect to form a T-junction? Many thanks
norkistar is offline   Reply With Quote
Old   January 26, 2013, 02:08
starter
sihaqqi is on a distinguished road
Hi
I have tried to do it because this is also my problem but I am getting errors on this one. If you have done it already perhaps you can guide me,
convertToMeters 0.001;
vertices
(0 0 0) // point 0
(0 0 60) // point 1
(0 0 -60) // point 2
(0 60 0) // point 3
(0 -60 0) // point 4
(1500 0 0) // point 5
(1500 0 60) // point 6
(1500 0 -60) // point 7
(1500 60 0) // point 8
(1500 -60 0) // point 9
(690 0 60) // point 10
(810 0 60) // point 11
(750 60 60) // point 12
(750 -60 60) // point 13
(750 0 750) // point 14
(690 0 750) // point 15
(810 0 750) // point 16
(750 60 750) // point 17
(750 -60 750) // point 18
blocks
hex (1 3 2 4 6 8 7 9) (20 20 1) simpleGrading (1 1 1)
hex (11 12 10 13 16 17 15 18) (20 20 1) simpleGrading (1 1 1)
edges
arc 1 3 (0 30 50)
arc 3 2 (0 30 -50)
arc 2 4 (0 -30 -50)
arc 4 1 (0 -30 50)
arc 6 8 (0 30 50)
arc 8 7 (0 30 -50)
arc 7 9 (0 -30 -50)
arc 9 6 (0 -30 50)
arc 11 12 (50 30 0)
arc 12 10 (-50 30 0)
arc 10 13 (-50 -30 0)
arc 13 11 (50 -30 0)
arc 16 17 (50 30 0)
arc 17 15 (-50 30 0)
arc 15 18 (-50 -30 0)
arc 18 16 (50 -30 0)
boundary
fixedWalls
type wall;
faces
(1 2 3 4)
(6 7 8 9)
(15 16 17 18)
(1 3 6 8)
(3 2 8 7)
(2 4 7 9)
(4 1 9 6)
(11 12 16 17)
(12 10 17 15)
(10 13 15 18)
(13 11 18 16)
mergePatchPairs
sihaqqi is offline   Reply With Quote
Old   January 28, 2013, 20:53
Bin Xu
Hi, my T-junction is formed by two cylinders, where the interface is not a arc which cannot be obtained by blockMesh. I just use GID to generate mesh and then import to OpenFOAM. Can you give a schematic illustration about your geometry and the location of each point? Best regards
[blockMesh] External flow around cube with blockMesh Woody8 OpenFOAM Meshing & Mesh Conversion 0 March 31, 2015 14:54
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 08:37
[blockMesh] tutorial 2.2 Stress(...) trouble with blockMesh colinB OpenFOAM Meshing & Mesh Conversion 8 January 22, 2012 10:32
How to generate tetrahedral/hybrid grids by blockmesh Tarak OpenFOAM 0 October 4, 2010 15:00
Cylindrical Obstacle Simulation Abdelraheem Main CFD Forum 0 August 5, 2010 05:57
