[Gmsh] boundary conditions with Gmsh stl
Old   June 22, 2012, 07:10
Default boundary conditions with Gmsh stl
Bercht is on a distinguished road
I created a geometry with Gmsh and exported it as an stl file. After that i meshed it with snappyHexMesh. But i dont have any boundaries defined with this method. Everytime i export an stl file with gmsh i get the msg, that physical groups can't be saved.
Is there any way i can create my boundaries with a combination of gmsh->stl->SHM ?
If no, what else could I use?
Bercht is offline   Reply With Quote
Old   July 10, 2012, 11:04
Mike Jaworski
Jaworski.Mike is on a distinguished road
Hi Bercht,
I think I had this problem as well. What I saw is that even if I defined physical entities in gmsh, that the stl file would only be listed as a single solid with the name "Created by Gmsh", which is useless if you need multiple patches. I worked around it by saving the different patches separately, running sed on the files to replace the "Created by Gmsh" with "minY" or whatever I wanted, and then putting the various stl files together with cat.
I've been wondering if I'm doing something wrong in Gmsh or if there's an easier way or a scriptable way to do the same thing, because it's a pain when there are a lot of patches on a part. Still, this is how I've been going from Gmsh->stl->sHM.
Cheers,
Mike
Jaworski.Mike is offline   Reply With Quote
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 01:44
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 18:02
Wrong multiphase flow at rotating interface Sanyo CFX 14 February 7, 2017 17:19
Velocity vector in impeller passage ngoc_tran_bao CFX 24 May 3, 2016 21:16
Low torque values on Screw Turbine Shaun Waters CFX 34 July 23, 2015 08:16
