[Gmsh] Using the mesh generated through gmsh in OpenFOAM
Old   July 4, 2012, 10:56
Default Using the mesh generated through gmsh in OpenFOAM
Nikhil
Nikhil Thakur is on a distinguished road
hello,
I am trying to convert the mesh generated through gmesh to Foam.But I am getting the following error:
--> FOAM FATAL IO ERROR:
No cells read from file "cyl.msh"
Does your file specify any 3D elements (hex=5, prism=6, pyramid=7, tet=4)?
Perhaps you have not exported the 3D elements?
file: cyl.msh at line 30956.
From function readCells(..)
in file gmshToFoam.C at line 721.
FOAM exiting
Nikhil Thakur is offline   Reply With Quote
Old   March 20, 2013, 04:39
Felipe Alves Portela
fportela is on a distinguished road
The error seems to be pretty clear, what kind of mesh are you trying to convert? Did you define the physicals properly in your .geo?
fportela is offline   Reply With Quote
Old   July 13, 2015, 09:22
KateEisenhower is on a distinguished road
I have the same problem. I managed to create physical surfaces and the physical volume and they even show up in gmsh. But how can you make your internal 3D cells physical?
Additional question: How can I display my internal mesh in gmsh?
Best regards,
Kate
p.s.: I think gmsh is an app which can produce beautiful products but it is very hard to understand how you actually do thing.
KateEisenhower is offline   Reply With Quote
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[Gmsh] Converting gmsh to OpenFoam Friendly OpenFOAM Meshing & Mesh Conversion 3 June 26, 2018 05:46
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
