[Other] How to create zero thickness internal walls in a given mesh in OpenFOAM?
Old   July 6, 2012, 06:34
Question How to create zero thickness internal walls in a given mesh in OpenFOAM?
notyet
karkar is on a distinguished road
I know using topoSet and subsetMesh along the lines of the mesh/moveDynamicMesh/simpleHarmonicMotion tutorial, one can cut holes into a mesh and obtain new patches. How can something similar be achieved with a vanishing hole, i.e. can a set of internal faces be turned into two touching patches with opposite orientation?
also posted at http://scicomp.stackexchange.com/q/2715/1669
karkar is offline   Reply With Quote
Old   July 9, 2012, 04:13
notyet
As gschaider posted at SE, I simply need to use the createBaffles tools
[Other] Internal Walls in mesh Rakkiran OpenFOAM Meshing & Mesh Conversion 6 April 15, 2021 02:48
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 14:24
Create thickness for zero thickness surface mesh zonexo Mesh Generation & Pre-Processing 0 May 28, 2016 11:35
[Commercial meshers] Fluent Mesh to OpenFoam: Internal Surface has to be a wall sebastian OpenFOAM Meshing & Mesh Conversion 6 October 21, 2010 04:36
