[CAD formats] Importing mesh files to OpenFOAM: is obj format viable?
Like Tree3Likes
  • 1 Post By sudo
  • 2 Post By cutter
Old   March 13, 2013, 17:41
Question Importing mesh files to OpenFOAM: is obj format viable?
sudo is on a distinguished road
Ok, so first of all I'm still a newbie in the whole CFD realm. For importing & exporting meshes into and from OpenFOAM, I have two questions:
1. Is the obj format a viable format to carry 3D mesh data?
2. If it is, then how (and I will need detailed instructions ) do I import a mesh in obj format to OF?
3. If it is only for surface meshes, could I still import it to OF, then use snappyhexmesh to do the volume meshing?
Reason I'm asking is that I can import mesh files from CCM+ (I know about the conversion tool, but that's for another thread) as wrl files that Mesh lab recognizes, and then does import it to obj.
Thanks in advance.
sudo is offline   Reply With Quote
Old   March 13, 2013, 20:09
JR22's Avatar
Jose Rey
JR22 will become famous soon enough
Check the motorbike tutorial ($FOAM_TUTORIALS/incompressible/simpleFoam/motorBike/ directory)
It pools the geometry from zipped .obj (motorBike.obj.gz) file in the "$FOAM_TUTORIALS/resources/geometry" directory.
After it is copied by the "Allrun" script into the trimesh directory, the snappyHexMesh calls it:
geometry
    motorBike.obj
        type triSurfaceMesh;
        name motorBike;
    refinementBox
        type searchableBox;
        min (-1.0 -0.7 0.0);
        max ( 8.0  0.7 2.5);
JR22 is offline   Reply With Quote
Old   March 15, 2013, 09:07
Thanks, I'll try that and report. I just want to mention that by comparing the mesh properties on the obj & wrl files with those from the original sim file, it is clear that the imported meshes on both wrl & obj files have way less elements indicating they are only surface meshes.
granzer likes this.
Old   March 5, 2014, 05:14
cutter is on a distinguished road
Some external tools require the STL file format. Use the OF tool surfaceConvert to convert between a variety of formats when necessary.
Cutter
amintalezade and yangzo like this.
cutter is offline   Reply With Quote
meshlab obj wrl
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 05:29
[Commercial meshers] Importing ICEM Multiregion Mesh In OpenFOAM Aditya Patil OpenFOAM Meshing & Mesh Conversion 1 May 8, 2017 21:33
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 13:39
