[Gmsh] high order node distribution gmsh
Old   July 16, 2012, 04:44
Default high order node distribution gmsh
jakob is on a distinguished road
I'm trying to create a 2D 4th order mesh of a simple wing with gmsh. My problem: I can't get the nodes at the leading and trailing edge to be evenly spaced (see picture), even though the conectors at the edges are evenly spaced. I'm guessing gmsh is is trying to optimize the nodes for curved elements. Is there a way to avoid this?
Any help will be much appreciated!
Jakob
jakob is offline   Reply With Quote
[ICEM] Error in mesh writing helios ANSYS Meshing & Geometry 21 August 19, 2021 14:18
Change export node ordering in Gmsh skrishnamoorthy Mesh Generation & Pre-Processing 0 August 11, 2015 20:42
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
High order compact finite difference schemes Mikhail Main CFD Forum 6 August 5, 2003 10:36
