[snappyHexMesh] snappyHexMesh doesnt snap
Like Tree6Likes
Old   June 9, 2015, 06:56
John Smith
mark_CFD_wind is on a distinguished road
Is it possible in the blockMeshDict to create two areas in effect, one close to the turbine where I can impose much more vertices and a larger one to deal with the macro flow effects? Or is this what the refinement is supposed to do?
Thanks,
Mark
mark_CFD_wind is offline   Reply With Quote
Old   June 9, 2015, 09:17
Saideep
Saideep is on a distinguished road
Hi Mark;
It basically gets complex if you have an irregular shape. Incase if you have a chance to split into hexahedral polygons then it is easy as explained in the cavity tutorial.
Also I just saw several videos in Youtube which shows the usage of "Adaptive meshes". {I didn't start working with that as of now may be someone can shed some light on that}. I just have an impression it is just a library so it shall be easy to use an adaptive grid also.
Saideep
Saideep is offline   Reply With Quote
Old   July 21, 2015, 15:24
Regis
Regis_ is on a distinguished road
Originally Posted by wyldckat View Post
The only thing that I can find to be potentially wrong is the "locationInMesh", which is a value too round and likely to get placed on top of a face or vertex of a cell.
Bruno, could you elaborate a bit more on this? From what I understood, as far as this point is inside the part of the geometry we wish to mesh, we're good. For instance, I use something like (5 5 5), that is, really round numbers.
Regis
Regis_ is offline   Reply With Quote
Old   July 25, 2015, 15:04
Retired Super Moderator
Bruno Santos
Greetings to all!
@Regis_:
The answer is essentially in the comment section of the "snappyHexMeshDict" files that are in the OpenFOAM tutorial cases, e.g.: https://github.com/OpenFOAM/OpenFOAM...xMeshDict#L140
    // NOTE: This point should never be on a face, always inside a cell, even
    // after refinement.
    // This is an outside point locationInMesh (-0.033 -0.033 0.0033);
    locationInMesh (-9.23149e-05 -0.0025 -0.0025); // Inside point
In other words, you should avoid situations where it's not able to calculate an accurate line between the location of this point "locationInMesh" and the centre/vertexes of a face (face of a cell).
Best regards,
Bruno
Regis_ likes this.
Last edited by wyldckat; July 25, 2015 at 15:05. Reason: added a few missing words
Old   March 17, 2018, 14:08
gouravjee is on a distinguished road
Greetings Thomas and welcome to the forum!
I suggest the following:
  1. Create a smaller case, based on this geometry, with a single connecting cylinder.
  2. Prepare the case for mesh generation. In a similar way to the tutorial "mesh/snappyHexMesh/flange".
  3. Test if it works.
    If it does, run Allclean and pack your case inside a zip or tar.gz file and attach to your next post. If too big, share online in some site like Dropbox.
This way it is easier to diagnose what's wrong, since we'll be able to test this ourselves.
Best regards,
Bruno
can anyone tell me what is wrong with my mesh. whenever i run it, i only get bounding box which i created with blockMesh
|  \\    /   O peration     | Version:  4.1                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap            true;
addLayers       false;
geometry
    mysurf.stl
        type triSurfaceMesh;
	regions
		input {name input;}
		walls {name walls;}
		output {name output;}
    cylinder.stl
	name cylinder;
// Settings for the castellatedMesh generation.
castellatedMeshControls
    maxLocalCells 100000;
    maxGlobalCells 2000000;
    minRefinementCells 10;
    maxLoadUnbalance 0.10;
    nCellsBetweenLevels 1;
    features
    refinementSurfaces
        regional.stl
            // Surface-wise min and max refinement level
            level (2 2);
	    input { level (2 2);    patchInfo {type	   patch;} }
	    walls { level (2 2);    patchInfo {type	   patch;} }
	    output { level (2 2);   patchInfo {type   patch;} }
    // Resolve sharp angles
    resolveFeatureAngle 24;
    refinementRegions
        cylinder.stl
            levels (2 2);
    locationInMesh (0 0 10);
    allowFreeStandingZoneFaces true;
snapControls
    nSmoothPatch 3;
    tolerance 2.0;
    nSolveIter 30;
    nRelaxIter 5;
        nFeatureSnapIter 10;
        implicitFeatureSnap true;
        explicitFeatureSnap false;
        multiRegionFeatureSnap false;
// Settings for the layer addition.
addLayersControls
    relativeSizes true;
    layers
    expansionRatio 1.0;
    finalLayerThickness 0.3;
    minThickness 0.1;
    nGrow 0;
    featureAngle 60;
    slipFeatureAngle 30;
    nRelaxIter 3;
    nSmoothSurfaceNormals 1;
    nSmoothNormals 3;
    nSmoothThickness 10;
    maxFaceThicknessRatio 0.5;
    maxThicknessToMedialRatio 0.3;
    minMedianAxisAngle 90;
    nBufferCellsNoExtrude 0;
    nLayerIter 50;
meshQualityControls
    #include "meshQualityDict"
    // Advanced
    //- Number of error distribution iterations
    nSmoothScale 4;
    //- Amount to scale back displacement at error points
    errorReduction 0.75;
writeFlags
    scalarLevels
    layerSets
    layerFields     // write volScalarField for layer coverage
mergeTolerance 1e-6;
gouravjee is offline   Reply With Quote
Old   March 17, 2018, 16:43
Bruno Santos
Quick answer:
  1. Please follow the instructions given here: How to give enough info to get help
  2. Because right now the best me or any one else can do is guess, and my best guess is that snappyHexMesh is as blind as we are regarding the geometry you are telling us that exists somewhere in 3D space.
Because:
  1. Yes, you do have a geometry somewhere, but where is it exactly?
  2. What is its size?
  3. Is the geometry truly inside the bounding box defined in blockMeshDict?
  4. Is the geometry ever crossed by one of the cell edges of the initial mesh?
  5. Did you know that there is a ton of information about how to use snappyHexMesh provided here: https://openfoamwiki.net/index.php/SnappyHexMesh ?
Old   March 18, 2018, 08:56
Quick answer:
Because:
I assume you might help me with this information
  • I have tried with unv format for creating bounding box.
  • To get familiar with snappyHexMeshI have used the following tutorial https://www.youtube.com/watch?v=n9xYN59v3po
  • My geometry lies within the bounding box as i have confirmed it in salome
  • it is a cylindrical geometry which has both height and radius of 300 cm
  • cylinder.stl indicates the internal solid region and rest are the faces.
Old   March 18, 2018, 14:19
Bruno Santos
I should have been more specific... Both me or anyone else, need the following information about the geometry and the initial mesh, in order to try and diagnose the problem:
  1. Which are the specific dimensions of the cylindrical geometry and where exactly is it located in 3D space? The specific X, Y, Z coordinates are very important. The units in which you defined the values are also very important.
  2. Which are the specific dimensions of the bounding box of the initial mesh? Again, the X, Y, Z values of the 2 extremes of this mesh are important.
  3. Which is the number of cell divisions that you have defined along X, Y and Z for the initial mesh?
[snappyHexMesh] Run snappyHexMesh steps (castellated, snap, addlayer) separately Glc OpenFOAM Meshing & Mesh Conversion 6 October 8, 2021 02:50
[snappyHexMesh] only snap edges of specific region with snappyHexMesh mike.franky OpenFOAM Meshing & Mesh Conversion 0 July 19, 2017 06:56
[snappyHexMesh] snappyHexMesh. irregular cells on snap stage Svensen OpenFOAM Meshing & Mesh Conversion 0 April 3, 2015 03:12
[snappyHexMesh] SnappyHexMesh refine but does not snap malaboss OpenFOAM Meshing & Mesh Conversion 6 December 10, 2014 05:31
[snappyHexMesh] snappyHexMesh failure to snap to geometry Yadasol OpenFOAM Meshing & Mesh Conversion 1 November 17, 2014 05:00
