[blockMesh] solidBodyMotion with cavity tutorial?
Old   July 19, 2012, 10:40
Default solidBodyMotion with cavity tutorial?
Alexander A
A.A. is on a distinguished road
Is it possible to do solidBodyMotion in the icoFoam-cavity-tutorial?
I want to rotate a solid block in the cavity, therfore I have changed the blockMeshDict file.
Is it possible to create an dynamicMeshDict-file (for the solidBodyMotion) and add it in the constant folder of the case cavity?
Or is it more complicated?
If I am not right please tell me the steps or the files I have to create to do a solidBodyMotion within the icoFoam-cavity-tutorial.
Regards and thanks,
Alexander
A.A. is offline   Reply With Quote
CFD Fluent tutorial - Shell and tube heat exchanger - PROBLEM tom96 FLUENT 1 May 21, 2018 00:24
Viscositymodel tutorial, problems when changing test case to cavity sur4j OpenFOAM Programming & Development 1 December 8, 2013 09:53
newbie problem with cavity tutorial miki OpenFOAM Running, Solving & CFD 8 September 2, 2012 15:22
[OpenFOAM] display panal dosn't refresh in tutorial 2.1 Cavity kEpsilon ParaView 0 February 27, 2012 10:43
The cavity Tutorial Ahmed OpenFOAM Running, Solving & CFD 0 August 2, 2009 10:56
