[snappyHexMesh] stl file with internal faces
Old   June 21, 2012, 15:57
Default stl file with internal faces
Mihai Pruna
mihaipruna is on a distinguished road
Hello fellow Foamists!
You have been most helpful so far. I really like this forum.
Let's say I have an STL file with two pipes that are modeled as cylinders, and they can be intersecting or abutting. Please see attached image.
I would like to model internal flow through the pipe. I have the outlet and inlet defined as the big circle and the small circle on the other side.
SnappyHexMesh meshes only one of the cylinders.
Is there a way to make it mesh inside the entire outer surface and ignore internal faces?
Probably too much to ask, eh ?
I currently don't have a way to remove the offending faces from the STL file.
Mihai Pruna's Bio
mihaipruna is offline   Reply With Quote
Old   June 21, 2012, 17:14
Retired Super Moderator
Bruno Santos
Hi Mihai,
Check the tutorial "mesh/snappyHexMesh/snappyMultiRegionHeater". But keep in mind that this means that you'll have multiple regions in you mesh!
Some examples on this subject:
But keep in mind: this does not get rid of the internal walls! To get rid of internal walls and merge all of the regions... I'm not certain how to do this. Perhaps the second post might help you with this, since I vaguely remember about removing an excess region...
Best regards,
Bruno
Old   June 21, 2012, 20:49
Mihai Pruna
Thanks Bruno, I will check those out. I figured getting rid of the patches would be the main issue...
Old   July 24, 2012, 13:32
Kalyan
kalyangoparaju is on a distinguished road
Mihai,
were you able to successfully mesh this geometry? how did you go about it?
Kalyan
kalyangoparaju is offline   Reply With Quote
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
[snappyHexMesh] SHM Layer Addition Phase dickcruz OpenFOAM Meshing & Mesh Conversion 4 November 1, 2018 07:05
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
