[blockMesh] 3D sphere - blockMesh
Like Tree3Likes
  • 1 Post By wyldckat
  • 2 Post By Traction
Old   August 21, 2012, 01:42
Default 3D sphere - blockMesh
bmt
bmt is on a distinguished road
Does anyone know a way of meshing a 3D sphere using only blockMeshDict? Is this even possible?
Thanks,
Ben
bmt is offline   Reply With Quote
Old   August 23, 2012, 14:43
Retired Super Moderator
Bruno Santos
Greetings Ben,
I think it's not impossible, but it's probably very arduous to do. There are a few solutions I can think of:
  • Do it interactively: http://openfoamwiki.net/index.php/Contrib/SwiftBlock
  • Cheat by using snappyHexMesh, as shown in the tutorial "mesh/snappyHexMesh/iglooWithFridges".
  • Use Plot3D format to design the mesh, then convert with datToFoam and then run blockMesh.
  • Use OpenFOAM's codeStream and code it directly into "blockMeshDict" See tutorial: "potentialFoam/cylinder/constant/polyMesh/blockMeshDict"
Best regards,
Bruno
babakflame likes this.
Old   August 23, 2012, 20:59
bmt
Thanks for that I will give it a go. I am looking to make a structured mesh to compare results against snappyHexMesh. Which of the above methods would be best for this purpose?
Thanks
Old   August 24, 2012, 17:52
Bruno Santos
SwiftBlock should be the easiest...
Old   February 23, 2013, 16:33
Eloïse
Eloise is on a distinguished road
Hi Ben,
Did you manage to do a 3D sphere in blockMesh? If so, I'd be interested to know how you did so
Thanks,
Eloïse
Eloise is offline   Reply With Quote
Old   February 25, 2013, 01:48
Karl-Johan Nogenmyr
kalle is on a distinguished road
my guess is that it is not possible without a blockMesh that can snap to surfaces (such a blockMesh does not exist as far as I know).
K
kalle is offline   Reply With Quote
Old   February 25, 2013, 08:08
Bruno Santos
Hi Kalle,
Strange... I though that with arcs and since wedges can be created, it should be possible to create a discrete sphere that is built with slices...
Best regards,
Bruno
Old   February 25, 2013, 09:34
startingWithCFD is on a distinguished road
In my archives I found the attached file. It was downloaded from somewhere in this forum (can't remember where and I have actually renamed the file :-/ Apologies to the original creator for not giving credit). I know that it should normally have a cubic block in the middle, but hey, it's a start. I hope it helps.
startingWithCFD is offline   Reply With Quote
Old   February 25, 2013, 09:45
Eloïse
Thanks a lot! I will have a look at it as soon as I have time
Regards,
Eloïse
Old   October 20, 2014, 20:25
suleman daud khan
sulemankhan22 is on a distinguished road
i made a sphere using only blockmesh. the pic is attached, it is an egg, with a hemisphere at the bottom
sulemankhan22 is offline   Reply With Quote
Old   October 26, 2014, 10:40
Bruno Santos
Greetings to all! And sulemankhan22, welcome to the forum!
You mentioned that you:
But then you state that you got:
Did you get this egg shape because you wanted, or do you believe that something went wrong?
If you believe something went wrong, then please share the "blockMeshDict" file you have.
Best regards,
Bruno
Old   November 1, 2014, 13:45
Default making 3D-sphere
  #12
ali naqi mohammadi
ali naqi is on a distinguished road
hi
i made sphere by using toposetDict!
it just needs to define radius and center of sphere
but it needs too many cells
ali naqi is offline   Reply With Quote
Old   July 29, 2016, 17:54
chun is on a distinguished road
Dear sulemankhan22, Dear ali naqi,
It is possible that I can know your method to build a 3D sphere mesh? I am interested about the mesh and the way to make it.
chun is offline   Reply With Quote
Old   July 29, 2016, 19:47
Phyonth is on a distinguished road
You can use snappyHexMesh to build a 3-D spher mesh. Either just a sphere or remove a spherical part from your domain. check this thread : "simple sphere with snappyhexmesh", might be useful.
Phyonth is offline   Reply With Quote
Old   July 30, 2016, 08:01
Karl-Johan Nogenmyr
Chun, do you mean something like this??
http://www.cfd-online.com/Forums/ope...tml#post523468
Old   July 30, 2016, 17:23
Dear kalle,
Yes! Your mesh looks perfect!! Thank you so much!
I will study your post.
Chun
Old   October 14, 2016, 07:40
Traction is on a distinguished road
Mr. Weller released an implementation and a tutorial for meshing a sphere with a single block in his dev repository. Right now I have no time to have a try but to me it looks very promising.
https://github.com/OpenFOAM/OpenFOAM...8a22a6d58be0ba
wyldckat and olegrog like this.
Traction is offline   Reply With Quote
[blockMesh] Sphere mesh with blockMesh - weird cells TheMadHungarian OpenFOAM Meshing & Mesh Conversion 9 March 18, 2023 06:20
[blockMesh] create a sphere with blockMesh decibelle OpenFOAM Meshing & Mesh Conversion 4 September 7, 2020 09:37
[blockMesh] BlockMesh with cylinder and halfsphere ich558 OpenFOAM Meshing & Mesh Conversion 0 April 11, 2019 05:17
[blockMesh] Sphere mesh with blockMesh - weird cells TheMadHungarian OpenFOAM Meshing & Mesh Conversion 1 October 22, 2018 09:03
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
