August 21, 2012, 01:42 |
3D sphere - blockMesh
Rep Power: 13 |
Does anyone know a way of meshing a 3D sphere using only blockMeshDict? Is this even possible? Thanks, Ben |
August 23, 2012, 14:43 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Ben,
I think it's not impossible, but it's probably very arduous to do. There are a few solutions I can think of:
Bruno
August 23, 2012, 20:59 |
Rep Power: 13 |
Thanks for that I will give it a go. I am looking to make a structured mesh to compare results against snappyHexMesh. Which of the above methods would be best for this purpose? Thanks |
August 24, 2012, 17:52 |
Bruno Santos
Rep Power: 128 |
SwiftBlock should be the easiest...
February 23, 2013, 16:33 |
Eloïse
Rep Power: 13 |
Hi Ben,
Did you manage to do a 3D sphere in blockMesh? If so, I'd be interested to know how you did so Thanks, Eloïse |
February 25, 2013, 01:48 |
Karl-Johan Nogenmyr
Rep Power: 21 |
my guess is that it is not possible without a blockMesh that can snap to surfaces (such a blockMesh does not exist as far as I know). K |
February 25, 2013, 08:08 |
#7 | |
Bruno Santos
Rep Power: 128 |
Hi Kalle,
Best regards, Bruno
February 25, 2013, 09:34 |
Rep Power: 13 |
In my archives I found the attached file. It was downloaded from somewhere in this forum (can't remember where and I have actually renamed the file :-/ Apologies to the original creator for not giving credit). I know that it should normally have a cubic block in the middle, but hey, it's a start. I hope it helps.
February 25, 2013, 09:45 |
#9 | |
Eloïse
Rep Power: 13 |
Regards, Eloïse |
October 20, 2014, 20:25 |
#10 |
suleman daud khan
i made a sphere using only blockmesh. the pic is attached, it is an egg, with a hemisphere at the bottom
October 26, 2014, 10:40 |
#11 | ||
Bruno Santos
Rep Power: 128 |
Greetings to all! And sulemankhan22, welcome to the forum!
You mentioned that you: Quote:
If you believe something went wrong, then please share the "blockMeshDict" file you have. Best regards, Bruno
November 1, 2014, 13:45 |
making 3D-sphere
#12 |
ali naqi mohammadi
Rep Power: 13 |
hi
i made sphere by using toposetDict! it just needs to define radius and center of sphere but it needs too many cells |
July 29, 2016, 17:54 |
#13 |
Rep Power: 11 |
Dear sulemankhan22, Dear ali naqi,
It is possible that I can know your method to build a 3D sphere mesh? I am interested about the mesh and the way to make it. |
July 29, 2016, 19:47 |
#14 |
Rep Power: 11 |
You can use snappyHexMesh to build a 3-D spher mesh. Either just a sphere or remove a spherical part from your domain. check this thread : "simple sphere with snappyhexmesh", might be useful.
July 30, 2016, 08:01 |
#15 |
Karl-Johan Nogenmyr
Rep Power: 21 |
July 30, 2016, 17:23 |
#16 |
Rep Power: 11 |
Dear kalle,
Yes! Your mesh looks perfect!! Thank you so much! I will study your post. Chun |
October 14, 2016, 07:40 |
#17 |
Rep Power: 12 |
Mr. Weller released an implementation and a tutorial for meshing a sphere with a single block in his dev repository. Right now I have no time to have a try but to me it looks very promising.
https://github.com/OpenFOAM/OpenFOAM...8a22a6d58be0ba |
[blockMesh] Sphere mesh with blockMesh - weird cells | TheMadHungarian | OpenFOAM Meshing & Mesh Conversion | 9 | March 18, 2023 06:20 |
[blockMesh] create a sphere with blockMesh | decibelle | OpenFOAM Meshing & Mesh Conversion | 4 | September 7, 2020 09:37 |
[blockMesh] BlockMesh with cylinder and halfsphere | ich558 | OpenFOAM Meshing & Mesh Conversion | 0 | April 11, 2019 05:17 |
[blockMesh] Sphere mesh with blockMesh - weird cells | TheMadHungarian | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2018 09:03 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 12:37 |
