[snappyHexMesh] What is the dimension of "minThickness" in SHM?
Old   October 20, 2012, 12:10
Default What is the dimension of "minThickness" in SHM?
Canakkale Dardanelspor
HakikiCanakkaleli is on a distinguished road
Could anyone please tell me what the dimension of "minThickness" under "addLayersControls" in "snappyHexMeshDict" is?
Many thanks in advance.
HakikiCanakkaleli is offline   Reply With Quote
Old   October 25, 2012, 04:23
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
normally it should be [m].
If you switch off the "relativeSize" you get an absolute value. If its falls the height of your cells depend on the nearest cells to your BC. Have a look at the snappyHexMesh Wiki and the presentation published this year at the 7th workshop
Tobi is offline   Reply With Quote
Old   October 25, 2012, 07:22
Thanks very much!
[ANSYS Meshing] Refinement dimension is not working Tasos ANSYS Meshing & Geometry 0 May 13, 2017 09:07
[snappyHexMesh] SHM not snapping to some surfaces Swift OpenFOAM Meshing & Mesh Conversion 13 January 4, 2016 01:56
buoyantPimpleDyMFoam dimension mismatch between Uf and phi Sumit07 OpenFOAM Programming & Development 2 June 17, 2015 03:55
[snappyHexMesh] SHM: feature edge snapping not conforming thab OpenFOAM Meshing & Mesh Conversion 3 November 26, 2012 14:04
[snappyHexMesh] sHM with cyclic patch on stl geometry johannesk OpenFOAM Meshing & Mesh Conversion 2 August 21, 2009 09:08
